Results 1 to 2 of 2
    Forum Newbie
    not applicable
    Aug 2012
    1
    Default HELP - Anamoly in Stress concentration
    I am joining two segments of a boom with a shank and ran the stress analysis on it. The shank diameter was the same as the hole in boom. I got the peak stress of 100 mil. Then I reduced the shank diameter of the shank by .5 mm and the peak stress dropped to 50 mil. This seems counter intuitive to me. Can anyone explain to me why this occurred? I'll send the design files if this description is not clear enough.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    What contacts did you use in each analysis?
    Attach your assembly here.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  1. Help in stress analysis
    By gattuso in forum Autodesk Inventor
    Last Post: 17th Feb 2011, 08:32 am
  2. Stress Analysis Help
    By mingyar in forum Autodesk Inventor
    Last Post: 16th Mar 2010, 01:41 pm
  3. stress analysis
    By prasanth14026 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Mar 2010, 12:32 pm
  4. Stress Calculations *HELP!!!*
    By Ritch7 in forum AutoCAD General
    Last Post: 18th Jan 2010, 11:40 am
  5. stress
    By Gors100 in forum AutoCAD General
    Last Post: 23rd Oct 2003, 08:01 am
