Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Senior Member
    AutoCAD 2009
    Nov 2010
    100
    Angry AutoCAD 2009 Shut down without warning
    When working on larger files AutoCAD shuts down without warning. I don't get the option of saving before it closes and it does not create a backup file that I can recover. No error message comes up either. It just closes as if I were to exit it.
    The last time it happend I had 3 drawing files open.
    2471 KB
    13370 KB
    21573 KB
    Each file is used for the job that I was working on. We used to have all drawings for the job in one file. They started to get really big so we break them out now.
    Could the files size have anything to do with AutoCAD just shutting down?
    Is there a way to stop this?
    The system we are running is:
    Windows XP Professional Version 2002 Serivce Pack 3
    Intel(R) Core(TM) 2 Duo CPU
    E7500 @ 2.93GHz
    2.93 GHZ, 3.25 GB of RAM
    C Drive has 298 GB with 37 GB used
    Any help or ideas would be great
    Thanks
    Matt
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,039
    All AutoCAD 2009 updates/service packs loaded?
    Have you purged and audited the individual drawing files?
    When did the problem first occur?
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,133
    Have you looked in your AUTOSAVE file location for a safety?
    OPTIONS > FILES > AUTOSAVE FILE LOCATION (this will show you the path for these files on your computer).
    You are not looking for a .bak file there, but rather the ac$, which if it hasn't been disabled should auto-save and the default is every 10 minutes.
    You will need to save the file type to .dwg if you find it, then open it as usual.
    Senior Member
    AutoCAD 2009
    Nov 2010
    100
    I purge all the time.
    Not sure if we ahve all the updates, patches and serives packs for 09. We have three, have not lookied into this yet.
    As for AutoSave it sucks. I turn it on and set it a 30 min and it seems to stay on for a few days, then I check it and it off. Not sure what the deal is but everyone in our office has this same AutoSave problem. When I same while working in the large files it takes a few seconds to complete the save. When AutoSave kicks in its kinda frustrating because while it save it locks up and you can't complete the task you started.
    I know there has been alot of discustion about AutoSave wheather it good or bad. So I am not going to debate that.
    I actual have a button on my mouse that is set to do a qsave. I use if very often, but not often enough sometimes I guess.....
    Could the large files that I have open be the problem?? Others at work don't seem to get files so large and they don't seem to have the same problems.
    Thanks
    Matt
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,039
    Do you purge Regapps first then do a purge > all?
    Do you Audit the drawing for errors?
    Do you pare down bloated scalelists?
    Do you manage your layer filters?
    Do you use any custom lisp routines?
    Do you have the InfoCenter enabled or disabled?
    What is Incremental Save Percentage set to?
    Have you done a REPAIR of your AutoCAD installation?
    Have you run a virus-scan on your hard drive?
    Do you get drawing files from outside sources?
    What have you done so far to troubleshoot the problem?
  6. #6
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,099
    Do you get any "Out of Memory" messages?
    Try using the Windows Task Manager to monitor Memory and CPU usage.
  7. #7
    Senior Member
    AutoCAD 2009
    Nov 2010
    100
    [Do you purge Regapps first then do a purge > all?Yes
    Do you Audit the drawing for errors?Not sure how to
    Do you pare down bloated scalelists?Only have the scales that we use
    Do you manage your layer filters?Yes
    Do you use any custom lisp routines?No
    Do you have the InfoCenter enabled or disabled?Enabled
    What is Incremental Save Percentage set to?50
    Have you done a REPAIR of your AutoCAD installation?not that I know of
    Have you run a virus-scan on your hard drive?yes, its done weekly
    Do you get drawing files from outside sources?Yes, but we swithc everything to the 0 layer then inport into our drawing then convert dims to ours and purge out the others
    What have you done so far to troubleshoot the problem?[/QUOTE]Uninstall / reinstall and check forums for simular problems
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,039
    Open one of the drawings and immediately run the AUDIT command. Here is an example of what you might see.
    Command: audit
    Fix any errors detected? [Yes/No] <N>: y
    Auditing Header
    Auditing Tables
    Auditing Entities Pass 1
    Pass 1 200 objects auditedAcDbMInsertBlock(439) Rows <= 0
    1
    Pass 1 1300 objects audited
    Auditing Entities Pass 2
    AcDbDictionary(1109) Owner Id Is Null Fix it
    Pass 2 300 objects auditedAcDbXrecord(14B3) Owner Id Is Null
    Fix it
    AcDbXrecord(14B4) Owner Id Is Null Fix it
    AcDbXrecord(14B5) Owner Id Is Null Fix it
    AcDbXrecord(14B6) Owner Id Is Null Fix it
    AcDbXrecord(14B7) Owner Id Is Null Fix it
    AcDbXrecord(14B Owner Id Is Null Fix it
    AcDbXrecord(14B9) Owner Id Is Null Fix it
    AcDbXrecord(148C) Owner Id Is Null Fix it
    AcDbXrecord(148D) Owner Id Is Null Fix it
    AcDbXrecord(148E) Owner Id Is Null Fix it
    Pass 2 1300 objects audited
    Auditing Blocks
    42 Blocks audited
    Total errors found 12 fixed 12
    Erased 0 objects
    After the audit save your drawing.
  9. #9
    Senior Member
    AutoCAD 2009
    Nov 2010
    100
    Quote Originally Posted by SLW210 View Post
    Do you get any "Out of Memory" messages? Yes, "AutoCAD is running out of system memory, Contiuing the currnet operation may result in program failure or loss of data. Do you want to cancel the current operation? YES / No
    I have to click NO, and save and retry the command. Some time it lets me and some time I have to close out AutoCAD and start over.
    Yes, it runs at 1%-3% CPU usage with spikes up to 11% some times 50% when I have really large files open
    PF Usage pretty much stays right around 1.46 GB
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,039
    Normally I recommend trying a REPAIR of AutoCAD prior to an uninstall/reinstall.
    Did you follow the recommended procedure for uninstalling/reinstalling AutoCAD as per AutoDesk's own published guidelines as found on the AutoDesk website?
  1. Autocad error/warning messages
    By mftbrothers in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Dec 2010, 12:53 pm
  2. AutoCAD Warning
    By serban.mihai in forum Software & Licensing
    Last Post: 11th Jul 2009, 12:39 am
  3. VBA to shut down AutoCAD
    By Olhado_ in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jul 2009, 12:26 pm
  4. AutoCad warning
    By wkellyxc in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jan 2008, 03:26 am
  5. Annoying AutoCAD LT Warning
    By bonehead411 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jun 2007, 11:14 am
