Results 1 to 6 of 6
    Junior Member
    AutoCAD 2012
    Mar 2012
    19
    Question Odd problem... my property tab is locked, and will not unlock.
    I keep my Properties tab anchored on the left side of my screen so I can just hover over it and pull up my object properties. As you know, once your mouse leaves the properties area, the tab automatically closes.
    When I want to fine-tune something and keep the tab open, I usually un-anchor the tab, and leave it floating in the middle of my drawing. When I am done editing the item, I re-anchor it. I have done this for many years with no problems.
    Recently my properties tab has been acting up. When I tell it to un-anchor (by clicking on the auto-hide button) the properties window detaches from the side of my screen and places itself near the middle of the screen.
    However, I cannot move it around. If I try to grab the outer edge of the window, a red crossed-out circle shows up, essentially telling me I am not allowed to do that. This has never happened before (that I can remember). I cannot move it anywhere. My only choice is to right-click on the edge and re-anchor it to the side of my screen... not what I want.
    What am I doing wrong? Why cannot I keep my properties window open while I work on another part of the screen?
    Thanks!
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,948
    Consider the LOCKUI Sytem Variable.
    "Potential has a shelf life." - Margaret Atwood
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    RenderMan is right on the button, in the bottom image you can see the available options information.
    You can also adjust these by right clicking on the workspace lock icon in the lower right corner of your screen.
    Additionally, even when your workspace is all locked up, if you hold cown the CTL button, while grabbing the item you want to move, you can do so.
    Have you ever considered, or tried using the QUICK PROPERTIES palette?
    I use mine all the time, it can be floating or locked, static or cursor proximitied, auto collapsing or not.
    It also offers the advantage of being customizable for virtually any type of entity.
    So that no matter what type of entity you select, the information shown on the palette is all of the
    information which you have specifically preselected for that type of entity.
    If you right click in the border you can select CUSTOMIZE which will take you to the following dialogue where you can
    customize all of those entity types as needed.
    I find the regular PROPERTIES annoying, because so much of the information provided is rarely of interest to me,
    so I have to dig through stuff I would rather not.
    Junior Member
    AutoCAD 2012
    Mar 2012
    19
    That was it!!!! Thank you guys so much. I have never intentionally locked that... not sure how that happened.
    Thank you again!
  5. #5
    AutoCAD 2012
    Nov 2011
    3,134
    Check your WORKSPACE, maybe it has changed to another one which has all of the elements locked?
    You might also want to check your workspace settings, to see whether it automatically saves any changes
    to the workspaces, or not.
  6. #6
    Civil 3D 2011
    Nov 2009
    3,948
    Quote Originally Posted by Dadgad View Post
    RenderMan is right on the button...
    *Tips hat*
    Quote Originally Posted by EnvisionMan View Post
    You're welcome; happy to help!
  1. Unlock all
    By Jessica28 in forum AutoCAD General
    Last Post: 27th Oct 2011, 08:05 pm
  2. unlock all layers
    By marmo in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jul 2010, 03:22 pm
  3. Problem with a surface being locked
    By homeraway in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Jul 2009, 10:12 pm
  4. Display locked view problem
    By HelloWorld in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Feb 2008, 10:51 am
  5. Layer Unlock
    By Brunello19 in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2006, 01:45 pm
