Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    7
    Default Disable or turn off item balloon tips
    I might be the only one in the world that gets really annoyed with those yellow text box popup tips every time the cursor passes over an item. The balloon tip that pops up is just an explanation of what the item is for or what it does when selected. I think I would be pretty safe in guessing that whenever a balloon tip appears there is a help button to go to if anyone really needs or wants to know about any particular item. So, to put an end to my frustration and annoyance, I would very much love to learn how these things can be disabled or turned off. I did find somewhere, a while ago, a way to edit the registry. But that was when I was using Windows XP. Now I'm using Windows 7 and the only place these balloons get under my skin is in AutoCad. Which is vanilla AutoCad version 2010. I guess I have to give up trying to insert an image. I have a *.jpg file but no matter what folder I put it in this "insert image" function don't or can't see it for some reason. If nobody understands what my post is referring to I'll just have to forget that I posted it. Thanks anyway!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,090
    Re: Tooltips.
    Go to Tools --> Options --> User Preferences. There, uncheck the box that says "Display hyperlink cursor, tooltip, and shortcut menu.
    Re: JPG
    IMAGEATTACH
    It doesn't matter where the jpg is. For all AutoCAD cares it could be on the far side of the moon. As long as you can browse to the right location you should be able to attach it.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,090
    System variable = ROLLOVERTIPS
    Set the value to "0".
    ROLLOVERTIPS is saved in the current profile.
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    7
    Thanks ever so much, ReMark!!!
    I will be a much happier man for the rest of my life. That goes for both of your solutions. Thanks again.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,090
    You're entirely welcomed.
    BTW...Welcome to the CADTutor forum.
  6. #6
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    7
    I don't want to be a DORK, but I was so happy to see replies to my post that I was a little hasty in being so happy. When I went to system variable ROLLOVERTIPS it was already set to 0. I think I must not have explained well enough what my problem is. That's what I wanted to attach the image to my post for. Not to attach an image into an Autocad drawing, if that's what I think you might have been talking about in your second post about attaching an image. I didn't explain that situation very well either. What I wanted to say was that I wasn't able to get my screenprint image of the balloon tip attached to my initial post. So I still got the two problems I posted about in the first place. However, don't get me wrong, I still am very pleased with the speed in which my posting was replied to.
  7. #7
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Welcome to CADTutor.
    There are another set of system variables dealing with tooltips, four of them, as shown in the image.
    I believe you want to set your TOOLTIPS variable to 0.
    Were you able to find the MANAGE ATTACHMENTS button in the Additional Options section which you access through the GO ADVANCED button in the lower right hand corner of the reply window?
  8. #8
    Super Member Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Independent Architectural Draftsman
    Construction
    Residential Homes, Construction and Renovation
    AutoCAD LT 2009
    Feb 2010
    Chuluota, Florida
    1,770
    Type options, click Display tab, and uncheck Show Tool Tips.
    For the attachment problem, first, click the Go advanced button under your post text window, then click the paperclip icon similar to outlook mail. Then click the Add Files button. Once the image is uploaded, click the Done button. The file upload bot will automaticly attach the new image to your post. Since you did the Go advanced, you should now click the Preview Post button to see what it will look like before it goes live on the forum.
    Yogi Berra: "In theory there is no difference between theory and practice. In practice there is."
  9. #9
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,233
    Quote Originally Posted by oegel View Post
    Turn off Quick Properties.
    2nd button from the right.
    Rob
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,090
    I'm pretty sure the OP is asking about the Tooltips feature and not Quick Properties.
  1. random veiwports turn off as i turn others on
    By mvrcad in forum AutoCAD Drawing Management & Output
    Last Post: 20th Apr 2011, 11:55 pm
  2. AutoCAD 2011 Feature Tips Tricks ~ 10 New Hatch Tips
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 2nd Apr 2010, 10:50 am
  3. Item Balloon - Leader
    By klew31 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Apr 2009, 01:43 pm
  4. Yet another Balloon question
    By mcguirepm in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Oct 2008, 09:32 pm
  5. Balloon Notifications
    By happyunited in forum AutoCAD General
    Last Post: 12th Sep 2008, 10:25 am
Tags for this Thread
