+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Forum Newbie
    Using
    Architecture 2002
    Join Date
    Aug 2012
    Posts
    1
    Default European windows
    Hi all,
    Drawing a inside and a outside wall with 8 cm of PU board insulation inbetween is no problem, but when i insert then a door or a window only 1 wall will be trimed.
    The inside wall and the insulation stay's solid.
    Is there a way to insert a window or door so the 3 wals are cutted out?
  2. #2
    Senior Member Bogbadbob658's Avatar
    Computer Details
    Bogbadbob658's Computer Details
    Operating System:
    Windows 7
    Motherboard:
    Asus P8P67 LE
    CPU:
    Intel 2nd Generation Coreā„¢ i5-2500
    RAM:
    8GB 1333MHz Dual Channel DDR3 SDRAM
    Graphics:
    512MB Nvidia GeForce Quadro FX 580
    Primary Storage:
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    Monitor:
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Using
    Architecture 2012
    Join Date
    Aug 2007
    Location
    Gloucester UK
    Posts
    252
    Default
    Unfortunately I can't open the file as I'm still on 2012 however it seemsfrom your description that you have built the wall construction out of 3 wallsof 1 component rather than 1 wall of 3 components. Doors and windows only cutout on 1 wall. So you need to make you wall up using 3 components (4 if thereis a cavity as well). If you can post the dwg again in 2010 format I will have alook at it to see if this is the problem.
Similar Threads
  1. Replies: 0
    Last Post: 8th Oct 2010, 07:59 pm
  2. 2d ( front view and side views) of European Standard Valves
    By bensoy in forum Blocks, Images, Models & Materials
    Last Post: 5th Aug 2010, 02:06 pm
  3. European measurement instead of american measurements
    By gicasdd in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jul 2008, 03:22 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
