Results 1 to 2 of 2
Thread: Linetype Scales
    Forum Newbie Leek0421's Avatar
    AutoCAD 2008
    Sep 2011
    6
    Default Linetype Scales
    I am having trouble with some scale of some linetypes. I've created 2 new linetypes that read -UW-UW- and -TR-TR- for under water and trench route. When i put them in a new drawing they show up as created but when i put them in an existing drawing they are not scaled correctly. Also when I put in some other created linetypes that i crested they come in correctly. all of the .lin files were created the same. Is this a problem the .lin file of the existing drawing. I did purge the drawing and i am still getting the same results.
    Full Member
    SAFeSTeR's Computer Details
    Windows 7
    Utilities
    SAFeSTeR's Discipline Details
    Overhead Cable CAD Technician
    Utilities
    AutoCAD 2012
    Jul 2012
    London, England
    86
    Maybe the LTSCALE of the existing drawing is different to the new drawing?
    Are your custom linetypes using the same scaling format?
    I'm not that conversant with custom linetypes so that is all I can think of...
  1. linetype scales in viewports
    By WillP in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2012, 11:35 am
  2. Xrefing and Linetype scales
    By funk in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Jul 2011, 07:21 pm
  3. Linetype Scales
    By woodman78 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 31st Mar 2010, 01:13 pm
  4. Linetype scales
    By watso75 in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2008, 10:41 am
  5. Insulation Linetype Scales?
    By Dan in forum AutoCAD Drawing Management & Output
    Last Post: 6th Sep 2006, 09:12 am
