... Not sure I fully understand what you're requesting; perhaps this is what you're after?
http://apps.exchange.autodesk.com/AC...-Geometry%3aen
I have a co-worker looking for a way to make certain strings of text into linework. Is this even possible? I thought there might be a LISP routine out there that does something like this.
Example: Carthage County Line = ---- -- ---- -- ---- -- ---- (or something)
T. Nelson
Sr. Survey Technician
http://www.saminc.biz
"The only thing left to do is EVERYTHING!" - Jesse James
"Potential has a shelf life." - Margaret Atwood
Thanks RenderMan but I'm not looking for the lines that make up the text to become linework.
I'm wanting something to read "County Line" and make a line in the drawing with a phantom linetype. I don't even know if something like this is even possible?
T. Nelson
You want "County Line" to be the command, or something found in the drawing... I am still not understanding.
If I am understanding you correctly, you're wanting a routine to detect a *Text entity that includes (or consists of) "County Line" in the Objects TextString, and then you want the code to create a *Line entity within the drawing's ModelSpace? Where?
Perhaps a before and after pic would help? More information is needed, methinks.
T. Nelson
Is this something like in a drawing legend? Could the start point of the line be a set vertical and horizontal offset from the insertion point of the text and the line a set length? Or does the line need start and end points?
Engage brain before mouth
"The German who types with a Yorkshire accent" - Dave Broada 2o1o
Maybe something like this?
Or have I misunderstood?Code:;; Text Linetype - Lee Mac ;; Creates and loads a custom linetype containing the specified text. ;; The linetype will use the Standard TextStyle in the linetype definition. ;; The space between dashes in the linetype is calculated based on the number of ;; characters in the supplied string, with an additional spacing of 0.05 drawing units. ;; Using a monospace font for the linetype will produce the best results. (defun c:txtlt ( / *error* des str tmp val var ) (defun *error* ( msg ) (mapcar 'setvar var val) (if (= 'file (type des)) (close des) ) (if (and tmp (findfile tmp)) (vl-file-delete tmp) ) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (cond ( (= "" (setq str (getstring t "\nSpecify Text for Linetype: ")))) ( (null (and (setq tmp (vl-filename-mktemp nil nil ".lin")) (setq des (open tmp "w")) (write-line (strcat "*" str "," str " ----" str "----" str "----") des) (write-line (strcat "A,.5,-.05,[\"" str "\",STANDARD,S=.1,R=0.0,X=0.0,Y=-.05]," (rtos (- (/ (strlen str) -10.0) 0.05) 2 1)) des) (not (setq des (close des))) (findfile tmp) ) ) (princ "\nUnable to create custom linetype definition.") ) ( (progn (setq var '(cmdecho expert) val (mapcar 'getvar var) ) (mapcar 'setvar var '(0 5)) (command "_.-linetype" "_L" "*" tmp "") (mapcar 'setvar var val) (vl-file-delete tmp) (tblsearch "LTYPE" str) ) (princ (strcat "\n" str " linetype created successfully.")) ) ( (princ (strcat "\nUnable to load linetype " str))) ) (princ) ) (princ)
Lee Mac Programming
Just another Swamper
Does this help?
Select "COUNTY LINE" and from that, create a line/polyline at a certain length with a PHANTOM linetype. (Just as an example)
T. Nelson
T. Nelson
T. Nelson
