Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2012
    Aug 2012
    1
    Default Multiple Attributes to a Single-Line Text
    Hi all, just wondering if it is possible to assign multiple attributes to a single line text within a block, and be prompted for them upon insertion.
    Cheers in advance,
    James
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Do you want one attribute which is all others combined but have the others invisible ? Maybe try fields. Else a lisp will do easy.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,986
    It may be useful to post a sketch of what you were looking for.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Full Member
    AutoCAD 2010
    Jan 2011
    35
    It really doesn't matter what you assign attributes to...line...text, they are part of the wblock. When you create an attribute definition (I've always made the promt the same as tag), you can make invisible,or backwards,or locked in position, and a few other things. And yes, you are prompted for a value even if invisible.
    When you insert the block, you will be asked for the values of each tag, and the single line of text will be your visible value, and the other tags will be invisible values. The invisible values can be included and visible in your table when you create the table.
  1. Convert Single line text to multi-line?
    By LKJR in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Jan 2013, 07:31 pm
  2. Single text box to multiple text boxes
    By cako in forum AutoCAD Beginners' Area
    Last Post: 26th Dec 2011, 03:25 pm
  3. change from single line text to multiline text
    By zarzar in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Oct 2009, 11:12 am
  4. Single Line Text
    By mr_mojo_risin in forum AutoCAD General
    Last Post: 21st May 2008, 02:31 pm
  5. single line text
    By kc27315 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jan 2008, 03:41 am
