Dear all,
I create Layout using Inventor, save the file into AUTOCAD DWG format,and then load it to AutoCad. After I open it, the predetermine dimensions (which I select to display the dimension in Inventor) are right. However, the dimension goes wrong if I do a new measurement on the Layout using Autocad. For example, 3 inch distance could be 0.212 in AutoCad (Note I just make up the number, I just want to show the problem is not inch to mm problem), .
Please help
Thanks
I use Autocad 2007 and Inventor 2008
Check the below thread and post #5:
http://www.cadtutor.net/forum/showth...ight=dimension
There is an image of Option you should check...
LT is still AutoCAD
