+ Reply to Thread
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 33
  1. #1
    Full Member
    Computer Details
    turboCAD's Computer Details
    Operating System:
    Windows7
    Using
    AutoCAD 2011
    Join Date
    Aug 2012
    Location
    București, România
    Posts
    88
    Default Modeling Operation Error: Inconsistent face-body relationships.
    Hello!
    I tried to slice a solid after a quite complex surface and received this error.
    "The Boolean operation on solid and/or surface bodies failed.
    SLICE failed for selected solid."
    What I have tried:
    I up-scaled the surface-solid ensemble by 10x but it didn't work(same error)
    I extruded that complex,multi-plane surface and then sliced it with a horizontal plane and got the desired solid BUT:
    I would like to know what the cause of that problem was and how it can be solved so that I can slice that solid following that surface.
    Thank you!
  2. #2
    Full Member
    Computer Details
    Operating System:
    Windows7
    Using
    AutoCAD 2011
    Join Date
    Aug 2012
    Location
    București, România
    Posts
    88
    Default
    correction: the solid I obtained by extruding that surface is close to the shape but not identical...so I must slice the solid following that shape.
    What can I do to overcome this error?
  3. #3
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    7,006
    Default
    attach file here.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  4. #4
    Full Member
    Computer Details
    Operating System:
    Windows7
    Using
    AutoCAD 2011
    Join Date
    Aug 2012
    Location
    București, România
    Posts
    88
    Default
    Quote Originally Posted by JD Mather View Post
    attach file here.
    Sir, I would not like to disclose this detail of the project as I would like to request a patent at a future date.
    I understand it would be the easiest way but I can not attach it.
    Any ideas are greatly appreciated .
  5. #5
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,484
    Default
    Without the drawing it is going to be difficult to determine the nature of the problem and how to fix it.
    No one here is interested in stealing your idea. Give us the bare minimum so we can see what the problem is.
  6. #6
    Full Member
    Computer Details
    Operating System:
    Windows7
    Using
    AutoCAD 2011
    Join Date
    Aug 2012
    Location
    București, România
    Posts
    88
    Default
    ok, this is what I did:
    before arriving to the complex surface, I had created the simple,plane surfaces and I saved a copy at every important step of the design; so I went back, took out the surfaces that I thought were the problem, and extruded the remaining complex surface...and it worked.
    Now I will show you the part that was causing the problem in this printscreen: the lateral pyramids
  7. #7
    Full Member
    Computer Details
    Operating System:
    Windows7
    Using
    AutoCAD 2011
    Join Date
    Aug 2012
    Location
    București, România
    Posts
    88
    Default
    imagine filling with water the cavity between those walls(extruding from blue surface upwards ) and then slicing along the walls that contain the water. that is what I could not do.As soon as I eliminated the pyramids(cyan color) I was able to extrude BUT I was not able to slice a solid along that surface.
    conclusion: I reached exactly the design I was aiming at but in a labouring fashion rather than an elegant engineering way
  8. #8
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,484
    Default
    We can't troubleshoot an image. Know what I mean?
  9. #9
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    7,006
    Default
    I can't say anything from the image, but -
    how far are you from the origin?
    would the surface terminate the solid (does it pass all the way through)? Doesn't look to me like it does.
    Can you reproduce the same error in a simplified example that doesn't reveal any proprietary information?
    Why are you using surface for this design - it looks to be all planar faces in the end.
    My guess is that since the information should be kept proprietary you will have to hire a consultant and have them sign a non-disclosure agreement.
  10. #10
    Full Member
    Computer Details
    Operating System:
    Windows7
    Using
    AutoCAD 2011
    Join Date
    Aug 2012
    Location
    București, România
    Posts
    88
    Default
    if I remove the pyramid on the wall, the problem disappears
Similar Threads
  1. Extruding Modeling Operation Error: Lateral curve does not intersect to_surface
    By returntocad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Jan 2012, 06:09 pm
  2. Mulit Body Modeling Video
    By MarkFlayler in forum Autodesk Inventor
    Last Post: 7th Dec 2009, 10:37 pm
  3. solid subtraction problem inconsistent face
    By leo55 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Mar 2007, 01:44 am
  4. "Inconsistent face-body relationships" - Subtracti
    By wilked in forum AutoCAD Drawing Management & Output
    Last Post: 5th May 2005, 06:38 pm
  5. Modeling Operation Error:
    By J-LYLE in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Feb 2005, 09:31 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
