Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
Thread: Squashed text
    Junior Member
    G-Man's Computer Details
    Windows 7
    Mechanical
    G-Man's Discipline Details
    Mechanical Draftsman
    Mechanical
    Mechanical 2013
    Aug 2012
    Perth, Australia
    11
    Default Squashed text
    Ive recently started using Auto CAD Mechanical 2013 (product design suite) and have been having real issues with certain types of text. Either when opening up an existing drawing or by pasting text.
    The text characters overlap each other. This can be resolved by changing the line type width factor from 1.00 to 1.01 which seems stupid.
    This does not happen with all text.
    Has anyone had similar problems, any fixes?
    Senior Member
    toberino's Computer Details
    Windows 7 64 bit
    NZXT: NEMESIS CASE
    ASUS M4A87TD EVO
    AMD Athlon II X4 2.8 GHz (overclocked to 3.525 GHz)
    Crucial 2GB DDR3 (x4)
    HIS Radeon HD 5450 1GB DDR3
    WD Caviar Green (varible speed) 500 GB
    WD 500 GB
    22" Acer Widescreen
    Architectural
    toberino's Discipline Details
    Structural Designer
    Architectural
    Architectural, Construction, Structural, Utilities, Surveying, GIS
    Architecture 2012
    Jul 2010
    Denver, Colorado
    110
    Just a thought....since all geometry has an x, y, z. Maybe the z is not set to zero???? I had a similar issue with a line type that had text in it that was snapping to a z coordinate that was not zero.
    Full Member Alex Moiceanu's Avatar
    Alex Moiceanu's Computer Details
    Windows 7
    Mechanical
    Alex Moiceanu's Discipline Details
    Engineer
    Mechanical
    Automotive & Aerospace
    AutoCAD 2012
    Feb 2011
    Romania
    46
    Have you tried to refresh the text('REFRESH' or 'REA' at command line).
    CAD-Systems.Think smart.Work less.
    http://www.cad-systems.org
    Find useful Tips & Tricks, free Tutorials and more...
    Junior Member
    Windows 7
    Mechanical
    Mechanical
    Mechanical 2013
    Aug 2012
    Perth, Australia
    11
    Thanks toberino but Z is already set to zero. Its must be somethig to do with the width factor as when you go in to the text style editor and change this it corrects the problem. But surely i shouldnt have to go into this and change it everytime i open a drawing. bizarre
  5. #5
    Junior Member
    Windows 7
    Mechanical
    Mechanical
    Mechanical 2013
    Aug 2012
    Perth, Australia
    11
    Quote Originally Posted by Alex Moiceanu View Post
    Does not work, if only it was this simple.
    Thanks
  6. #6
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Welcome to the forum.
    I would suggest that you set up your current TEXT STYLE defined WIDTH as.9,
    and include the TEXT STYLE definition in your default .dwt template, assuming that you probably use one.
    Are the texts which you are copying annotative?
    In model or paperspace?
    You should be able to select all of the TEXT items, I would use my QUICK PROPERTIES palette to filter select those,
    and confirm, or adjust all of their STYLE settings to be your desired STYLE.
  7. #7
    Junior Member
    Windows 7
    Mechanical
    Mechanical
    Mechanical 2013
    Aug 2012
    Perth, Australia
    11
    Quote Originally Posted by Dadgad View Post
    Thanks Dadgad,
    I have set up my DWT as suggested,
    The text styles are not annotative.
    The problem occurs when opening supliers, customers drawings that previously used to open fine in AutoCAD lt 2009. Its already slightly annoying that everytime i open a drawing that i have to enter the text style editor and change it to 1.01 or 0.9 etc..i.e. something different from the std 1.0.
    Is there a way of changing the text settings of drawings that are non native ie someone else has created, in the main options maybe?
    Thanks
  8. #8
    AutoCAD 2012
    Nov 2011
    3,134
    There is no way to do it in OPTIONS, nor with system variable settings that I am aware of.
    Like I said in my last post, I would change the STYLE or the WIDTH in my QUICK PROPERTIES palette as shown in the image.
    My guess is that if you just change the STYLE to match the one in your drawing, that the width issue will be resolved without further heroics.
    I suppose you could create an ACTION MACRO to do this with the ACTION RECORDER in your right click shortcut menu, that would be quite simple, or add a lisp to your startup suite to do it.
    I would probably still do it as shown, as it only takes a second to do it this way.
    I understand full well your frustration at having to do anything at all, as you did not previously have this issue with 2009.
  9. #9
    Junior Member
    Windows 7
    Mechanical
    Mechanical
    Mechanical 2013
    Aug 2012
    Perth, Australia
    11
    Okay thanks Dadgad,
    I guess im going to have to do that for now, until there is a better resolution.
    Maybe I need to swap back to AutoCAD LT !! LOL
    Thanks
  10. #10
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,106
    Can you post a drawing with text that gets "squashed"?
  1. Routine to add modified text below existing text (copy/replace?)...
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2011, 08:44 am
  2. Change multiple Dimensions measured text into normal text?
    By apsonwane in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jun 2011, 09:31 am
  3. Circles appear squashed a bit in 2D dreawings
    By richardnet in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 31st Oct 2010, 12:21 pm
  4. Replies: 7
    Last Post: 20th Nov 2008, 01:33 pm
  5. Replies: 0
    Last Post: 6th Sep 2006, 09:19 am
