Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2010
    May 2009
    5
    Default Adding info from google maps
    Hi,
    I'm working on a project looking at modifying cycle routes. I just discovered that they've been added to google maps and I was wondering if there's a way to import the cycle routes from an area on google maps into CAD. If not, I can draw them in on the OS but it would be time wasted if there's a way.
    I thought maybe on AutoCAD WS on chrome, but it seems limited on the mapping features available.
    Thanks in Advance
    Kev
    Full Member
    SAFeSTeR's Computer Details
    Windows 7
    Utilities
    SAFeSTeR's Discipline Details
    Overhead Cable CAD Technician
    Utilities
    AutoCAD 2012
    Jul 2012
    London, England
    83
    So you want to import the road markings or similar of the the cycle route from google into AutoCAD?
    I'm pretty sure this is not possible. I've done many many TTM (temporary traffic management) drawings and I used google maps to view the road markings, but I always had to draw them manually (or create blocks for certain things like directional arrows).
    However, I think http://www.promap.co.uk/ can supply UK OS maps for use in AutoCAD which contain road markings. Not sure how much they cost but if I remember correctly, you can pay for them by a user defined area (instead of 1km tiles), so, depending on the size of your project, and if it is based in the UK, the site might be worth looking at.
    Forum Newbie
    AutoCAD 2010
    May 2009
    5
    Cheers for the response. Not exactly (being able to extract roadmarkings etc would be impressive since it's from a photo!).
    If you see the image attached, you can see the cycle paths which google shows in bright green. I'd like to be able to take that layer and add it to a drawing.
    I've manually drawn it in now, but for future reference it'd be interesting to know. The GIS database info would need to be accessible or something I guess, I'm not really sure how it would be achieved. (that's where you clever folk come in )Cycle routes.jpg
    Senior Member Squirltech's Avatar
    Squirltech's Computer Details
    Windows 7 Enterprise, Service Pack 1
    @xi
    32.0 GB
    230 GB
    Dual Dell 21"
    Surveying
    Squirltech's Discipline Details
    Senior Survey Technician
    Surveying
    Civil 3D 2009
    Oct 2010
    30 15' N, 97 44' W
    162
    I use a program called Global Mapper and it will convert just about anything to just about anything. I have used it to go from: KMZ/KML to SHP, DWG to SHP, DWG to KMZ/KML and so on. Global Mapper is pretty user friendly and you can do a batch conversion/projection without even opening the source file. You might want to give it a look.
    T. Nelson
    Sr. Survey Technician
    http://www.saminc.biz
    "The only thing left to do is EVERYTHING!" - Jesse James
  1. ArcGIS for AutoCAD with BING/Google maps
    By jammie in forum Civil 3D & LDD
    Last Post: 11th Feb 2012, 10:33 am
  2. Overlay 2D AutoCAD DWG on Google Maps with AutoCAD WS
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 31st Mar 2011, 02:37 pm
  3. Incorporating Google Maps Street View
    By ScottnSharrer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Oct 2010, 01:22 pm
  4. Adding info to the plot log cvs file?
    By Ace in forum AutoCAD General
    Last Post: 29th Apr 2010, 09:27 pm
  5. google maps/live maps as xref/underlay.
    By OMEGA-ThundeR in forum AutoCAD General
    Last Post: 12th Jun 2009, 02:45 pm
