Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: CAD question?
    Forum Newbie
    3ds Max 2013
    Aug 2012
    9
    Question CAD question?
    Hi
    I have been working with Cinema 4d and 3D Studio Max before, when I was a regular 3d artist.
    But now I want to try out CAD models.
    So I got some "First time questions", That I need answered. So guys please help me out
    1. Is it any different if I model in Polygons and print it as a STL file? Or must all the "products" be made with CAD softwares?
    2. Does 3D Studio Max uses for Cad modelling? I have nurbs features.
    3. Whats the different to use a Polygon File extensions format instead of a Nurbs format? Will my product will be print wrong? (if I use polygon).
    4. Does all model with CAD? Can I model with Polygon to get the same result?
    Thanks! for the help!
    /John
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Based on your questions I'm going to guess that Autodesk Alias or Autodesk Inventor might be a better choice for your 3D "art".
    Students can download these Autodesk products for free from http://www.autodesk.com/edcommunity
    You might watch some of the classes (in AutoCAD mesh modeling, Alias or Inventor) here http://au.autodesk.com
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    3ds Max 2013
    Aug 2012
    9
    Hi
    Thanks for the fast reply!
    But I can model in Cinema 4d or 3D Studio Max, Is it a must to model in Nurbs?
    Or can I use polygon modelling and use it as good as Nurbs? Will it be any different of the end product if I use Nurbs or polygon? or is it the same printing result? just a different teqniue.
    Thanks.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    I think you must use NURBS modeler for engineering/manufacturing purposes.
    But I am confused by your "is it the same printing result" statement.
    Are you referring to 2d paper prints or photographic type output (digital or print)
    or
    are you referring to one of the Rapid Prototyping/3D Printing/Additive Manufacturing processes (stl)?
  5. #5
    Forum Newbie
    3ds Max 2013
    Aug 2012
    9
    Lets say I`m modeling a "product" for production, That will be send to manufacturing printing process.
    I can`t model in AutoCAD, but I can model Polygons in Cinema4d and then save it from Cinema4D to a .STL file.
    Will this work? or do I need to learn AutoCAD and model in Nurbs to get the manufacturing process correct.
    What I mean with the "printing result" is: Will it work? or dont the manufacturing allow .STL Polygons?
    Thanks!
  6. #6
    Forum Newbie
    3ds Max 2013
    Aug 2012
    9
    Or does some manufacturing works with polygons and some not?
    Maybe it depends which manufacturing who prints it ? Some allowes only Nurbs (Then I must create it with Autocad), If allowed Polygons (I can use Cinema4d),... Am I right?
  7. #7
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    If you can save the file as *.stl file type then it should be usable by the RP machine.
    Post an example here of your *.stl file.
  8. #8
    Forum Newbie
    3ds Max 2013
    Aug 2012
    9
    I have attached a Test.STL.
    Its a sphere with booleans, That I saved as a .STL from Cinema4d.
  9. #9
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Looks good to me.
    I recommend you increase the facet resolution for a smoother model.
    Let me do some testing with this model tomorrow for final verdict.
  10. #10
    Forum Newbie
    3ds Max 2013
    Aug 2012
    9
    So my model works fine for manufacturing print? Why dont People model in Cinema4d and then save it as a .STL then? This is much easier instead of learn AutoCAD.
    How much resolution should I use?, Until its very smooth?, can it be too much?
    Do I need any unique scale? Lets say it much always be in millimeters.?
    Thanks for all the help btw!
  1. Replies: 1
    Last Post: 23rd Nov 2010, 02:27 pm
  2. question about .net
    By RONK79 in forum .NET, ObjectARX & VBA
    Last Post: 5th Aug 2010, 11:19 am
  3. C# Question
    By wannabe in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Nov 2008, 12:26 am
  4. command line up arrow question, and grip edit distance question
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2008, 03:15 pm
  5. SU question
    By JBullseye74 in forum SketchUp
    Last Post: 7th Mar 2006, 08:38 pm
