+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Junior Member moonh's Avatar
    Discipline
    Civil
    moonh's Discipline Details
    Occupation
    Design Engineer
    Discipline
    Civil
    Using
    AutoCAD 2012
    Join Date
    Mar 2012
    Location
    South Carolina, United States
    Posts
    18
    Default .CTB General question
    Hello everyone, and my question for today is
    Is the color yellow(50) always difficult to see on a set of printed plans. I am using standard "acad.ctb" that came w/ my CAD. The color shows up fine on my CPU while drafting, but it is visually difficult to see once plotted out on paper.
    I believe there is a way I can adjust the .CTB to where yellow plots out more ledigble, but I'm not sure how to do that.
    Thanks, and once again any help will be greatly appreciated.
  2. #2
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell Precision T7500
    CPU:
    Xeon Dual Core E5503 2.0Ghz
    RAM:
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    Graphics:
    nVidia Quadro 3800
    Primary Storage:
    300Gb, 10K rpm
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2014
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    3,402
    Default
    You can change the layers that use yellow to a darker yellow color, or edit the ctb to use a darker yellow, or any color you want. I assume you want to plot in color?
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  3. #3
    Discipline
    Civil
    Occupation
    Design Engineer
    Discipline
    Civil
    Using
    AutoCAD 2012
    Join Date
    Mar 2012
    Location
    Posts
    18
    Default
    I am plotting in black & white. Usually when drafting, we put centerline of a road in yellow & Overhead power lines in yellow. Yes I could just change the layer color to something else, to create a neat ledigble plot, but I was trying to figure out a way to properly adjust the appearance of the color yellow on my plots. On the AutoCad Color Index, I thought "color 50" was a standard yellow.
  4. #4
    Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    CPU:
    RAM:
    Graphics:
    nVidia Quadro 3800
    Primary Storage:
    300Gb, 10K rpm
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    Occupation
    Discipline
    Mechanical
    Details
    Using
    Mechanical 2014
    Join Date
    Nov 2007
    Location
    Posts
    3,402
    Default
    I am really confused now, you say you plot in B&W then go on to say you want a way to adjust the appearance of the color yellow on plots.
    As I said in my first post, open the CTB and adjust things there, but just set it to plot black and then change the line weight and or the screening. Standard yellow is #2 but #50 is very similar.
    I mentioned changing the layer color because I thought maybe you were plotting in color and yellow is always going to be hard to see on a white sheet of paper.
  5. #5
    Discipline
    Civil
    Occupation
    Design Engineer
    Discipline
    Civil
    Using
    AutoCAD 2012
    Join Date
    Mar 2012
    Location
    Posts
    18
    Default
    adjusting the screening and line wieight fixed the issue. My lines were coming out extremely faded, to the point where you could barely see them. I had already tried adjusting the screening, but when I started increasing the line weight, that worked.
  6. #6
    Super Member RobDraw's Avatar
    Using
    AutoCAD 2011
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    1,273
    Default
    Don't forget to save your modifications to a different .ctb file with a unique name.
    Rob
Similar Threads
  1. General Newbie CAD Question - UNDER RAD / OVER RAD !?!?
    By simes in forum AutoCAD Beginners' Area
    Last Post: 28th Jul 2011, 10:10 am
  2. Drawing 3D general question
    By cso in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th May 2010, 10:04 pm
  3. x reference general question
    By addesigns in forum AutoCAD General
    Last Post: 3rd Dec 2009, 06:17 pm
  4. autoLISP general question
    By X in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2006, 08:05 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
