+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Forum Newbie
    Using
    Inventor 2013
    Join Date
    Aug 2012
    Posts
    4
    Default Proper way to export images for review (i.e.spec/cut sheets)
    What is the correct way to prepare a part or assembly to show to coworkers or clients?
    For instance, I have a part or assembly ... I'd like to put it in an image or pdf format and show them the part and dimensions .. like spec sheets or cut sheets?
    We do own Autodesk Publisher 2012. I'm working with Inventor 2013.
  2. #2
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,906
    Default
    This is a pretty wide open question.
    On paper or electronically?
    You can probably show everything you need with dwf and they can view with internet browser (don't need Inventor).
    Publisher is for fancier graphics for customers/clients.
    You will need to define your needs better for best advice.
    How much Inventor experience do you have?
    How many idw files have you made?
    How much experience with Inventor Studio?
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  3. #3
    Forum Newbie
    Using
    Inventor 2013
    Join Date
    Aug 2012
    Posts
    4
    Default
    I'm an Inventor newb. I took AutoCAD classes back in 2002 and recently started designing again.
    I am designing a spec sheet for one of our products. I'm doing this in photoshop. I want to put a black and white image of the product with dimensions into this .psd file in high quality.
  4. #4
    Forum Newbie
    Using
    Inventor 2013
    Join Date
    Aug 2012
    Posts
    4
    Default
    The JPG image is my spec sheet i'm designing. The PDF has a product design with dimesions at the bottom of it .. I want to do something similar with my product and put it in the area that says "CAD Illustration here"
    What is the process of putting parts or assemblies into presentation format like this for viewing? If I knew what it was called, I could do some research on it or watch some videos.
    Can you suggest any good learning videos or reading material to help me understand preparing files for presentation format?
    Thanks
  5. #5
    Forum Newbie
    Using
    Inventor 2013
    Join Date
    Aug 2012
    Posts
    4
    Default
    Attached here is one part of my assembly. This was rendered in studio. I could use this with a WHITE background but need the dimensions to show. How would I do that??Image.png
  6. #6
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,906
    Default
    You can change the background to whatever you want (and maybe make it some alpha color that will be transparent in your document.
    Have you tried in idw a dimensioned drawing (if isometric view like your image hit the spacebar as you place dimensions to change text orientation).
    You can set the sheet color through Tools>Document Settings.
    Start new idw file> place view(s) from ipt or iam and dimension. The view (s) can be shaded.
Similar Threads
  1. Replies: 6
    Last Post: 26th Apr 2012, 06:29 am
  2. Snagit Trick - Export all Captured Images
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 4th Jan 2011, 01:00 am
  3. AutoCAD-Export High Resolution *.bmp Images
    By clark in forum Blocks, Images, Models & Materials
    Last Post: 11th Nov 2009, 11:05 am
  4. PC spec help
    By A1DWG in forum Hardware & Operating Systems
    Last Post: 12th Jan 2009, 03:21 pm
  5. spec
    By S.P.I in forum Hardware & Operating Systems
    Last Post: 23rd May 2008, 01:12 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
