Results 1 to 3 of 3
    Full Member Keywordkid's Avatar
    Keywordkid's Computer Details
    Win 7
    Architectural
    Keywordkid's Discipline Details
    CAD Manager
    Architectural
    AutoCAD 2012
    Jun 2012
    London, UK
    70
    Default First run error before custom script
    Hi all,
    I have a head scratching puzzle.
    With lots of help from previous posts I have a working script to preload a default workspace and rename it as the users loginname so they can amend to their hearts content but get my initial startup with the addition of the read only enterprise.cuix, lots of testing on one PC all looks fine
    Moving to a new test machine with no previous login, my batch scripts preload the required folders, files and shortcuts, plus a registry merge of the desired base arg files. The first run of the custom shortcut does it's normal installation thing and then stops with:
    When I ok the error my script loads and all is well, subsequent AutoCAD sessions do not repeat the problem, however a log out and log back in does!
    I'm using AutoCAD 2012 on Windows 7, I suspect it is something to do with merging the arg file but I have not found any other way to get my custom pathed shortcut to work without doing this, here is the shortcut detail:
    "C:\Program Files\Autodesk\AutoCAD 2012 - English\acad.exe" /p "C:\ACAD\%username%\Support\Barclays-Profile.arg" /b "W:\CADWorkspace\05-ClientResources\BarclaysStandard\BarclaysStart.scr "
    The odd thing is I have a second shortcut that is loaded in the same way but does not create this error, any suggestions gratefully received, particularly if there is a better way to get my script to run without merging the arg.
    Thanks.
    Win 7
    Architectural
    CAD Manager
    Architectural
    AutoCAD 2012
    Jun 2012
    London, UK
    70
    The lack of response has been overwhelming, everyone must have been engrossed in the Olympics!!
    For anyone who is interested; I persevered and eventually deduced the problem to be with the arg file, although I believe the way IT have configured user policies also to be an issue. Anyway I did a great deal of trial and error testing by deleting sections out and re-running until I eventually found a section that caused the error to appear. I can't say I'm comfortable with the solution and wonder whether something is going to come back and haunt me as a result but as far as I can tell everything is running well and performing as I hoped.
    I'd be interested to know how others manage to deploy new client setups for user's individual logins without manually going machine to machine and using the user's credentials to ensure correct deployment, sigh...it was so much easier in MicroStation.
    Senior Member tomhamlet's Avatar
    tomhamlet's Computer Details
    Windows 7
    DELL Desktop
    AMD phenom 2 (6 core)
    6gig
    1 gig
    1 tb
    Dell widescreen
    See details...
    tomhamlet's Discipline Details
    mechanical engineer, draftsman
    See details below.
    At Denios, we design storage and containment units for hazerdous materials. We also design cranes, racks, or whatever the customer needs.
    Mechanical 2011
    Oct 2012
    Louisville, KY
    121
    If you think that the script is running into problems with the way your IT department has folders set up, I would suggest saving your script to a personnal folder, if available.
  1. Mysterious Custom Hatch Error
    By ShadowVFX in forum AutoCAD General
    Last Post: 4th May 2012, 12:29 am
  2. Create a custom table using a script
    By whitehouse431 in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jan 2011, 08:48 pm
  3. Error when adding custom drawing property
    By lfe011969 in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jan 2011, 07:20 pm
  4. inventor 10 help files script error
    By rookie37 in forum Autodesk Inventor
    Last Post: 9th Mar 2010, 01:00 am
  5. Custom script no longer works in '07
    By f700es in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jul 2007, 04:09 pm
