Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Forum Newbie
    AutoCAD 2002
    Aug 2012
    6
    Default Trouble with picking viewports for locking and scaling
    Hey Guy's, My properties button has quit picking viewports. When I pick the viewport outline, my properties dialog box say's "no selection" Sometimes I get a blank dialog box and have to repick the viewport to get the dialog box to give me information. However, it will not give me the information to set viewbox scale, or will not let me lock the modelspace area so that I can zoom without altering my scale setting. Is there a setting that has gotten changed or what. A week ago the command was working fine. Hopefully, someone might have a solution to my problem. HELP!!!
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,133
    Welcome to the forum.
    This problem sounds like the viewports are in modelspace, and were created with the Viewport Configuration Dialogue?
    If so, you can neither LOCK nor SCALE them, although you can zoom them to resize.
    OR
    Are you talking about your PROPERTIES or your QUICK PROPERTIES palette?
    If you are talking about your QUICK PROPERTIES, then right click inside the palette, select CUSTOMIZE,
    then set the appropriate choices to be included in the VIEWPORT QUICK PROPERTIES palette display.
    Click SAVE when you are finished making your selection.
    AutoCAD 2012
    Nov 2011
    3,133
    Perhaps, if you do mean your quick properties, you need to right click on the quick properties ICON, SETTINGS > then set as shown in the image.
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,221
    It sounds more like the viewport is on Defpoints and the "0" layer is frozen or off.
    Rob
  5. #5
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    It's also possible that the viewport is clipped as a polyline. The OP is selecting the viewport and the polyline at the same time, which at first glance don't register as an object.
    breaking AutoCAD on a regular basis since 1991
  6. #6
    AutoCAD 2012
    Nov 2011
    3,133
    Quote Originally Posted by CyberAngel View Post
    This sounds like a good hypothesis CyberAngel.
    In my first response I suggested that maybe the viewport had been placed on DEFPOINTS layer, but later edited it out.
    Hard to know til we know, could be any of these really.
  7. #7
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,102
    It will still have "All (#)" for however many items are selected, not "No Selection".
    Most likely RobDraw is correct. Posting the drawing file would help diagnose, there have been bugs with properties not showing as selecting in past AutoCAD releases.
    Dadgad, the OP indicates the use of AutoCAD 2002, no Quick Properties.
  8. #8
    AutoCAD 2012
    Nov 2011
    3,133
    Quote Originally Posted by SLW210 View Post
    You make an EXCELLENT point, one I noticed very early in the thread, but forgot about.
  9. #9
    Forum Newbie
    AutoCAD 2002
    Aug 2012
    6
    Thanks for responding to my problem. I have looked at your suggestions and most of them have addressed "quick properties". I am working in ver. 2002 and it does not have a button for this. I went into drafting settings and there is no a tab for "qp" there either. I have tried to reload my menu files to see if that would solve my problem but to no avail. Layer 0 is not causing a problem and I am not overriding a pline with my view boxes. I have always used defpoint layer with on problems to make my viewports so that they would not print if I forgot to turn them off for pirnting. At 71 years old, I may be having a "senior moment" and am not using the correct sequence in opening the properties dialog box. My process is to pick the viewport boundry and highlight it, then pick the properties button and bring up the dialog box to let me scale the viewport or lock it so I could zoom within the viewport window without changing my scale in the process. Now, when I do this, all I get is the dialog box that gives me the alphabetic or categorize options with the box telling me "no selection" at the top window. The only option I have left is to reload my autocad program from scratch and start over. This will be a pain but unless you guys know of any settings in autocad that may have gotten changed by my stupidity, then it may be my only option. Thanks again for your time and suggestions. Jim T.
  10. #10
    Forum Newbie
    AutoCAD 2002
    Aug 2012
    6
    by the way, SLW210 suggested that I post a drawing file to let you look at but I am not sure how to do this. Let me know the process and it will be done, Jim T.
  1. trouble scaling
    By Stephen Shafer in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Apr 2009, 06:59 am
  2. Problem with locking viewports and changing to layouts
    By erik_NL in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Mar 2008, 10:08 pm
  3. locking layers in viewports
    By rms55 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Feb 2008, 03:27 pm
  4. Dimensions and Locking Layers in Viewports *Please*
    By JaketheMan in forum AutoCAD Drawing Management & Output
    Last Post: 12th May 2007, 10:46 pm
  5. Locking Viewports...
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2006, 04:28 pm
