Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    Default AutoCad can not find system printer
    my Acad 2000 program has somehow lost the ability to print. When I select my printer I get a series of error messages that says #1(system printer must be installed in order to connect to this device) #2 (this plotter configuration cannot be used. Either the device cannot be found, the driver cannot be found, or the driver has a problem. The none device has been substituted). My system printer works for all other applications, and has worked on Acad in the past. I have attempted to use the Plotter Manager to no avail. Any suggestions appreciated. Thank you hman
    Senior Member
    jammie's Computer Details
    Ubuntu / XP / W8
    Civil
    jammie's Discipline Details
    Design Technician
    Civil
    AutoCAD 2012
    May 2006
    Ireland
    299
    Hi hman,
    Is it a network printer or local to your machine? What type of printer are you using? What OS are you running?
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    Hello Jammie-- this printer is local to my machine. I am using a Cannon iP100 Series. computer operating system Windows XP Professional version 2002. I know that the DWG files are fine because I can export to another computer and print them without any problem. this printer configuration problem is exclusive to my system. I did use this computer and printer without problem for a year or more, before it got itself glitched.
    any help appreciated, thank you, hman
    Senior Member
    Ubuntu / XP / W8
    Civil
    Design Technician
    Civil
    AutoCAD 2012
    May 2006
    Ireland
    299
    I'd say its a printer driver compatability issue between AutoCAD and the Cannon iP100 printer.
    When did the issue start? Have you updated your printer driver recently? I notice that the current printer driver for the ip100 is v2.17 on the cannon website, is this what you are using?
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,048
    Have you tried uninstalling the printer then reinstalling it?
  6. #6
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    Hello Jammie-- I did re-install and update driver a couple of months ago, but just to be on the safe side I followed your advice and deleted, than reinstalled the printer a couple of minutes ago. No dice. the same problem. This problem started over a year ago. i uploaded something from the web for a project that I was working on, and i remember it caused me to do something with my print manager. I wasn't able to print again after that. I have actually uninstalled acad from my system, and reinstalled but have not been able to get rid of this glitch. I really do not think that it is a acad/printer problem. My Acad print menu does not see any of the normal windows print options. It should see several options just like my system files show, but it only shows stuff that the print manager put in all of which are .pc3 files. I don't know what this means, but they all give me the same error message.
    Thank you for the help. hman
  7. #7
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    Go to Options, Files, Printer Support File Path, and finally Printer Configuration Search Path. What does it show? Now in Windows drill down to that folder, are your printers / plotters .pc3 files located there? If not then you need to change that in Options, Files, ... to the correct path.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  8. #8
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    hello rkent--
    I went to the 'options menu' and drilled down through all paths as you have suggested. all path and directions seem to be in order. it points me to acad2000/ plotter and my printer is listed there. however I get the same error message as before. Telling me that a windows printer must be installed in order to use this device.
  9. #9
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    I would go into windows and re-do adding the printer. Then go into AutoCAD and re-do adding that printer to a .pc3. I seem to remember having to do that in the past and had no idea why it needed to be done, just a corrupt file I suppose.
  10. #10
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    hello rkent--
    I did the uninstall/reinstall in both the windows printer, then on acad. I actually did this three times today. No dice. same error message. I can still forward dwg file to another computer and print just fine, just cannot print from this computer.
  1. HP printer crashes AutoCAD 2013
    By DANIEL in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 13th Apr 2012, 08:33 pm
  2. Replies: 6
    Last Post: 13th Jul 2011, 02:19 pm
  3. How do I script a printer change - <Network> printer name has spaces in it??
    By ILoveMadoka in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 4th Jan 2011, 08:14 pm
  4. Know where I can find a Section View of a Radiant Heating System?
    By exodusms in forum AutoCAD Beginners' Area
    Last Post: 18th Nov 2009, 05:13 am
  5. Printer doesn't work now with AutoCad 07
    By chee_dee in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2008, 12:31 pm
