+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
  1. #21
    Junior Member
    Using
    AutoCAD 2000
    Join Date
    Aug 2012
    Posts
    13
    Default
    Hi--Thank you for the link. What exactly is this program.. I am kind of cautious about uploading a generic program that simply says Setup.exe.
  2. #22
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,106
    Default
    The link I posted is to instructions for the error message you have. No Setup.exe on the link I posted.
    You should be going to this page.....
    Attachment 36627
  3. #23
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,058
    Default
    So I don't think this system is finding any of the windows system printers.
    Sounds like a classic "pathing" problem to me.
    Is this "setup.exe" file for a printer driver?
    I too went to the link provided by SLW and there was no reference to a setup file there. Please clarify.
  4. #24
    Super Member RobDraw's Avatar
    Using
    AutoCAD 2011
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    1,224
    Default
    Just throwing some straws out for grasping to see if it helps. Windows system printers do not have the .pc3 extension. Also, that dialog wants to plot to file using a DWF Classic plotter. Does AutoCAD automatically pick plot to file if it can't see the printer in the .pc3 file? How about uninstalling the Cannon and the DWF classic and deleting that .pc3 file and starting from scratch?
    Rob
  5. #25
    Junior Member
    Using
    AutoCAD 2000
    Join Date
    Aug 2012
    Posts
    13
    Default
    Hello SLW-- Thank you for the attached page. This describes my exact problem. I will go through the selected fixes one by one. Problem being that i am on the road at the moment, and won't be able to work on fix until next week when I have access disk with printer driver. thank you.
    RobDraw-- yes you seem to be on the right track. the acad system seems to drop down through the printer/plotter list. if first one isn't found it goes to the next. This Classic plot is with DWF extension is on the bottom of the list. I will try deleting all plotter files and starting over as you have suggested. Good idea will keep you posted.
  6. #26
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Oct 2012
    Posts
    1
    Default
    Hi There, have had this exact problem over the last few weeks after upgrading our PC with a "new" ex lease unit.
    Followed all instructions above listed in forum and still got nowhere and finally had a brain wave and tried something that fixed the problem and now I can see all my windows system printers!
    My solution (although it may not be yours) was to make sure the service for Net.TCP Port Sharing was enabled. The moment I started the service and restarted Autocad there they were!
    Start > Run > services.msc >Net.Tcp Port Sharing Service > Automatic > Start
    I had battled with this for soooo long I felt that i had to share my fix in the hope it may help someone else.
    Cheers,
  7. #27
    Junior Member
    Using
    AutoCAD 2000
    Join Date
    Aug 2012
    Posts
    13
    Default
    Hi wadeeng-- Thank you for the suggestion. I did go into Net.TCP port sharing and revise the connection. Still no-dice for me. ACAD simply can not find my system printers. I know that this is a configuration problem, but am at a loss how to resolve this issue. I am continuing to email my DWGs to another computer where I can plot.
    thanks.
Similar Threads
  1. HP printer crashes AutoCAD 2013
    By DANIEL in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 13th Apr 2012, 08:33 pm
  2. Replies: 6
    Last Post: 13th Jul 2011, 02:19 pm
  3. How do I script a printer change - <Network> printer name has spaces in it??
    By ILoveMadoka in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 4th Jan 2011, 08:14 pm
  4. Know where I can find a Section View of a Radiant Heating System?
    By exodusms in forum AutoCAD Beginners' Area
    Last Post: 18th Nov 2009, 05:13 am
  5. Printer doesn't work now with AutoCad 07
    By chee_dee in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2008, 12:31 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
