Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
  1. #11
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    hello rkent--
    Is there such a thing as the acad print manager file being corrupt. Can i get another of these files and overwrite, or replace? Just grasping at straws. I have been living with this problem for a long time
  2. #12
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    Post another screen shot of your plot dialog with the error message not on top. It looks like you may have plot to file checked somewhere as even though you have the Canon selected it is showing a DWF plotter and plotting to a file with .dwf extension.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  3. #13
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    hello rkent.. you are correct. it is trying to plot to a .dwf extention I have never seen that extension. How do I change it back to .dwg?
  4. #14
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    I don't have 2004 here to check but there must be a setting in options to plot to .dwf for plots. Just a guess really, hopefully someone with 2004 can chime in. Also post at autodesk.com, they my have a 2004 section.
  5. #15
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    thanks rkent--
    i will keep on plugging along with this. thanks for the help
  6. #16
    Forum Newbie
    AutoCAD 2013
    Jul 2012
    2
    Superb information can be found on these kind of boards. Many thanks guys.
  7. #17
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    hman, When you are setting the cannon for plotting in AutoCAD, somewhere in that setup is a "plot to file" or "plot to dwf" checkmark, watch in there for that and uncheck. Look for the Ports tab while in the .pc3 file.
  8. #18
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    hello rkent--
    I will look for the canon set-up as you have suggested. When I have been in the set-up before, I know that it is messed up because it does not offer any ports for my canon printer. I cannot find anything to check or uncheck, but I will keep digging. Hopefully I will stumble on the correct page, and all will be well.
  9. #19
    Junior Member
    AutoCAD 2000
    Aug 2012
    13
    hello rkent--
    I really think that the error comes before the canon printer install. I believe it is somewhere in the acad configuration, as my print menu does not show any network printer, this is not isolated to the cannon. please see printer screen shot attached. These are my printers on my other acad systems they would all be visible, but not on this computer. So I don't think this system is finding any of the windows system printers.
  10. #20
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,125
    See if THIS helps.
  1. HP printer crashes AutoCAD 2013
    By DANIEL in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 13th Apr 2012, 08:33 pm
  2. Replies: 6
    Last Post: 13th Jul 2011, 02:19 pm
  3. How do I script a printer change - <Network> printer name has spaces in it??
    By ILoveMadoka in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 4th Jan 2011, 08:14 pm
  4. Know where I can find a Section View of a Radiant Heating System?
    By exodusms in forum AutoCAD Beginners' Area
    Last Post: 18th Nov 2009, 05:13 am
  5. Printer doesn't work now with AutoCad 07
    By chee_dee in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2008, 12:31 pm
