Lentezza Posted August 13, 2012 Share Posted August 13, 2012 Hello, I use Cad for Mac 2011. I am looking for a way for switching views quickly when drawing 3d. For the moment I use VIEW and then TOP, SE or whatever. It´s a bit slow. Also I couldn´t find out how the actual view is indicated. Maybe you can tell me something about those things. Cheers Len Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 13, 2012 Share Posted August 13, 2012 Does the Mac version have a View Cube - upper right corner of screen? Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 13, 2012 Author Share Posted August 13, 2012 Sometimes asking makes my brain work...Going back to the drawing I just fund a ahort cut. V is enough for VIEW, T for Top, and so on... Anyway, other replies still very welcome besides there was the other question... Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 13, 2012 Author Share Posted August 13, 2012 Thank you for the hint!!! Made me find out I am moving in 2d model space...(where the View Cube was set "off" up to now...) Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 13, 2012 Share Posted August 13, 2012 I would suggest you use the VIEW toobar, which makes it easy, intuitive and quick. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 14, 2012 Share Posted August 14, 2012 You can save Views say you want about 20degs up from the front slightly to the right call it say V1. Then you can do shortcuts V1 jumps to view 1 maybe save a few in a template, then either menu, lisp or buttons, if you create new views just name them saved macro value. (Defun c:V1() (command "-view" "R" "V1") ) Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 14, 2012 Author Share Posted August 14, 2012 Thank you for the answers. Finally found out how to costumize the toolbars....Quite different than I remember doing it on the pc, but there´s a lot to costumize... The view saving seems a quite handy thing. Found out that saving is quit easy: V and then "save" from the appearing dropdown menu. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 16, 2012 Share Posted August 16, 2012 You can also use the vpoint command this was basicly replaced by the view cube but started out life way back when. Vpoint 1,1,1 X,Y,Z etc Quote Link to comment Share on other sites More sharing options...
