Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Help needed
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    6
    Default Help needed
    Hi, first of all.
    Have a small question for someone who knows Solid, how to "cut the lump" in assembly composed of 2 parts like on image.
    So, I need to smooth cylinder with eliptical cap shape.
    Thx.
    Picture:
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Why not model as multi-body solids to begin with?
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    6
    I'll give it a try, havent really used multi-body that much, I need it to be in 2. parts for further manifacturing, so I always sketched part by part
    Senior Member bhamze's Avatar
    not applicable
    May 2010
    Florida
    164
    Edit the part in context of the assembly. Create a 0 offset of surface, then use cut with surface to remove geometry from part. If you can provide a part and better explanation of what your trying to achieve I can provide an example.
    Certified SolidWorks Expert -Advanced Surfacing, Mold Tool, Weldments, Drawing Tool and Sheet Metal Specialist
    http://www.solidworkslessons.info/
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by the condition View Post
    You can push out the two individual parts when finished. Multi-body really simplfies stuff like this.
    It does create an extra file - but all your dimensions are in one master file.
  6. #6
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    6
    Quote Originally Posted by JD Mather View Post
    THX, multibody seems very useful.
  7. #7
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    6
    podnica 152 R-taljan_donja.SLDPRThalf-coupling asme b16.11 1-2 6000 nipple.SLDPRT
    Quote Originally Posted by bhamze View Post
    It worked with multi-body, but I did similar in CATIA like you suggested, so I'm interested to learn that in Solid. I'll provide two parts in attachment.
  8. #8
    not applicable
    May 2010
    Florida
    164
    Is the attached what your trying to accomplish? If so, let me know and I will provide an example. If not, can you explain in better detail of what your trying to do?
  9. #9
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    6
    yes, that's it
  10. #10
    not applicable
    May 2010
    Florida
    164
    Here you go. Does it help?
  1. Help Needed
    By jlythgoe in forum SolidWorks
    Last Post: 15th Jan 2012, 09:03 pm
  2. help needed C3D
    By matt sad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Aug 2011, 12:29 pm
  3. another FAQ help needed
    By Alan Cullen in forum AutoCAD Drawing Management & Output
    Last Post: 8th Nov 2007, 08:54 am
  4. Greetings first,help needed second!
    By dspin in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Aug 2006, 05:11 pm
  5. Help Needed Please.!!
    By Tack in forum AutoCAD General
    Last Post: 23rd Mar 2006, 09:58 pm
