You could use the FILTER command, it is highly customizable, and enables you to set up and SAVE filters for use another time, or to create one on the fly.
Hi,
I'm using QSELECT to select all objects on a layer, sometimes I need to select objects from 5-7 layers.
Right now I use QSELECT, select 1 layer, click OK, open QSELECT again, select another layer and repeat. Is there a faster way to do this without scripts?
On another non-related question... I'm sure some of you do site drawings, how do you measure a curve? Some restaurants or cafes have a rounded serving counter, any tips on how you measure the radius to plot into autocad?
Use a RADIUS dimension, DIMRADIUS at your commandline, or select the icon from your dimension toolbar or panel.
You may choose to show an internal and an external radius dimension.![]()
The Radial dimensions are probably the most appropriate, but then too there are times when you might want to show a measurement along an arc too.
You can see the ARC icon on the dimension toolbar to the left of the RADIUS icon, or use DIMARC at the commandline.
to add to the above post,
after invoking the DIMARC and selecting an ARC, you can type "P" for partial, and measure part of an arc if you need
AutoCAD 2012 & AutoCAD MEP 2011
I believe the OP is asking how to determine the radius of the curve on the ACTUAL serving counter to use in the drawing.
I would use a tape measure/straight edge or framing square if available.
Why not open the layer manager, grab all layers, unselect the 5 layers, lock the others, you are ready to grab objects.
"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
sometimes it is easier to measure the straight bits or points in a cartesian fashion (like on a grid) and then plot the curve on after.
