Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Join objects
    Full Member igones's Avatar
    igones's Computer Details
    Win 7
    PHENOM II X4 965
    4Gb
    Gtx550Ti
    SSD 128Gb
    HD 1T
    19''
    Architecture 2012
    May 2012
    BRAZIL
    32
    AutoCAD Join objects
    Hi everyone,
    I'd like to know how can i join these objects. I'm trying to use PEDIT command but no success. The objects are not touching so it's not possible?
    How can i join two objects that aren't touching each other.
    Thanks!
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,993
    For sure you cannot join them, but you can tie them toghether - check the BLOCK or GROUP commands.
    The join concept refers to contiguous entities being in contact - please check the help of PLINE and PEDIT commands.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,132
    The FUZZ FACTOR definition at the end of the series of commands allows you to specify the FUDGE factor (meaning how great an opening will be bridged).
    Or you could just use the FILLET command, with 0 as the fillet distance. Then JOIN them after they have all been extended by the FILLET command.
    If you don't want to have to respond to queries about changing nonpolylines to polylines?
    Set your PEDITACCEPT SYSTEM VARIABLE TO 1 (at your commandline).
    AutoCAD 2012
    Nov 2011
    3,132
    Quote Originally Posted by MSasu View Post
    For sure you cannot join them, but you can group them toghether - check the BLOCK or GROUP commands.
    Mircea, I suspect that igones doesn't want to JOIN the two circles, and instead wants to JOIN the two lines defining the rectangle.
    I've been wrong before though, so let's see what he means.
  5. #5
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    igones, you better provide more information as your original problem description doesn't make logical sense in AutoCAD functionality terms. (especially PEDIT)
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  6. #6
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    756
    Quote Originally Posted by JD Mather View Post
    that's probably why they posted in the beginner forum. is the language of AutoCAD the only one you speak?
    i think you're after the BLOCK command - this means when you select one entity, all the others connected inside the block are selected too. is this what you're trying to do?
  7. #7
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    Select them both, right click, Group, Group.
    Or use the Block command.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  8. #8
    Win 7
    PHENOM II X4 965
    4Gb
    Gtx550Ti
    SSD 128Gb
    HD 1T
    19''
    Architecture 2012
    May 2012
    BRAZIL
    32
    Let me try to explain it better.
    I know how to turn lines into polylines. But, i want to turn different objects into one object.
    And other thing I want to know is to "group" objects, like when i click in one part of the object (rectangle) the whole object (rectangle + circle) be selected.
    Sorry for my Brazilian English
  9. #9
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,035
    As others have already said the command you are looking for is GROUP or BLOCK. Have you used either of these commands before?
  10. #10
    Win 7
    PHENOM II X4 965
    4Gb
    Gtx550Ti
    SSD 128Gb
    HD 1T
    19''
    Architecture 2012
    May 2012
    BRAZIL
    32
    No, never. But i'm gonna google it now.
    If i fail using these commands, i'll post here.
    Thanks!
  1. Join multiple objects
    By aspitanis in forum AutoCAD General
    Last Post: 30th Mar 2012, 05:54 pm
  2. Polyline join doesn't want to join with arc?
    By Furion in forum AutoCAD Beginners' Area
    Last Post: 3rd Jan 2012, 06:35 am
  3. How do I join these 2 objects?
    By resting in forum 3D Modelling
    Last Post: 7th Mar 2010, 11:17 pm
  4. Join in PE
    By alijahed in forum AutoCAD General
    Last Post: 9th Feb 2009, 07:36 am
