Results 1 to 3 of 3
    Forum Newbie
    AutoCAD LT 2009
    Aug 2012
    1
    Default Part file location in title block?
    Hello,
    I’m trying to save myself a bit of time and was wondering if it is possible to have part of the file location displayed in the title block?
    The current title block we are using shows the full file location of the drawing but I was wondering if it is possible to show only part of this?
    The reason I am asking is that when a project progresses to the next stage we have to go through each drawing and change the status to warrant, tender, construction etc. so I am looking for a way that this can be done automatically and I was thinking if only part of the file location could be used this process could be done by simply moving the drawings to the next folder? Our projects folders are split down in to subfolders for planning, warrant, tender etc. which corresponds with the status field on your layout. So instead of having to update this status manually every time the project progresses this would update to the folder that the drawings are in.
    Example:
    I:\Projects\## - Project Title\Drawings\Construction\Ground Floor Plan.dwg
    Am trying to get the "Construction" folder to display in the status field on the layout.
    I hope this makes some sort of sense and someone knows what i am trying to get at. If there is another way to achieve what I am looking for all suggestions are welcome.
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Welcome to CADTutor.
    That is an interesting idea.
    Here is another one http://www.lee-mac.com/macatt.html
    Lee Mac's got you covered. Thanks Lee!
    It will change attributes without even opening the drawings.
    He also has Batch Find & Replace, http://www.lee-mac.com/bfind.html
    not sure which might work best for you, check them out.
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,057
    Quote Originally Posted by Dadgad View Post
    but only if you are running full AutoCAD. The OP has LT so can't use LISP.
    I think it can be done with a diesel expression in the field ddata but I have had very limited success in getting the middle part of a field.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  1. link title of file to the title block inside
    By 19cruthik68 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jun 2012, 09:25 am
  2. replace block moves the symbol in the block location help!
    By shipmanlights in forum AutoCAD Beginners' Area
    Last Post: 13th Apr 2012, 08:24 am
  3. Link the file name to parts/tags in the title block
    By Robert J in forum AutoCAD Beginners' Area
    Last Post: 10th Nov 2007, 03:34 pm
  4. CTB file location
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2005, 03:55 pm
  5. BAK File location
    By geoffc in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jun 2005, 06:43 pm
Tags for this Thread
