+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,906
    Default
    Quote Originally Posted by Bill Tillman View Post
    I will start this process again from scratch tonight...
    No need to start over - it is a simple Scale to make 1"=1mm
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  2. #12
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,128
    Default
    Quote Originally Posted by JD Mather View Post
    -DWGUNITS will scale it also.
    Code:
    Command: -dwgunits
    Drawing units:
      1. Inches
      2. Feet
      3. Millimeters
      4. Centimeters
      5. Decimeters
      6. Meters
    Unit for length <1>: 3
    Drawing unit display formats:
      1. Scientific
      2. Decimal
    Linear display format <2>:
    Linear display precision <5>:
    Scale objects from other drawings upon insert? [Yes/No] <Yes>:
    Match INSUNITS to drawing units? [Yes/No] <No>: y
     ** WARNING: you have changed the unit for this drawing database.  **
     ** All new objects will be drawn according to the new unit, but   **
     ** existing objects will not change size unless you specifically  **
     ** ask to have automatic scaling occur.                           **
    Scale objects in current drawing to reflect change in units? [Yes/No] <Yes>:
    Include objects in Paper Space? [Yes/No] <Yes>:
Similar Threads
  1. IFC import to Autocad MEP 2011
    By orbik171 in forum AutoCAD General
    Last Post: 8th Dec 2010, 04:00 pm
  2. problems with autocad import
    By arrivalanche in forum Rhino
    Last Post: 12th Nov 2009, 04:59 am
  3. STEP Import for AutoCAD
    By ReMark in forum Catch All
    Last Post: 13th Jan 2009, 04:52 pm
  4. Import DataCAD to AutoCAD
    By Rupert9819 in forum AutoCAD General
    Last Post: 4th Dec 2008, 05:56 pm
  5. Import fonts into AutoCAD?
    By mine62R in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Mar 2008, 12:25 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
