Results 1 to 8 of 8
    Junior Member
    Multi-disciplinary
    Taylor Gibson's Discipline Details
    Draughtsman, Power Generation
    Multi-disciplinary
    Piping design, P&IDs, Equipment design
    AutoCAD LT 2013
    Aug 2012
    Northants, England
    13
    Default AutoCAD opens new every time.
    If I open another dwg from Windows Explorer, AutoCAD opens up new every time, even though it is already open. How can I stop this happening? If I've used Explorer to search for a dwg I then have to retrace my steps using open, otherwise I end up with lots of AutoCADs open. I've looked in options but I can't see anything in there to prevent this happening. Thanks.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,041
    First, please ensure that both TASKBAR and SDI system variables are set to 0. If this doesn't help, then please do a search on the Forum since this issue was discussed previously.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Junior Member
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD LT 2013
    Aug 2012
    Northants, England
    13
    Thanks, I've found the solution in the similar threads section. It's the "opens with" AutoCAD DWG Launcher in Explorer which is the answer. I'll try search first next time.
    Junior Member
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD LT 2013
    Aug 2012
    Northants, England
    13
    Hmmm! Well I tried it once & it worked. I've just demonstrated it to one of my colleages & it's opened AutoCAD new again. Back to the drawing board, so to speak.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,457
    From Windows Explorer>Tools>Folder Options>File Types>DWG>Advanced>Open>Edit
    Action:
    open
    Application to be used to perform action:
    "C:\Program Files\AutoCAD 2010\acad.exe" "%1"
    Use DDE Checked
    DDE Message:
    [open("%1")]
    Application:
    AutoCAD.r19.DDE
    DDE Application Not Running:
    blank
  6. #6
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,268
    I've always found that method of opening drawings buggy especially on machines with more than one version AutoCAD. You think you get it set the way you want and it eventually changes. You can copy the folder path from the Windows Exporer address bar and paste it into the open dialog box in AutoCAD and hit open to get you to the folder where the drawing resides.
    Rob
  7. #7
    Junior Member
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD LT 2013
    Aug 2012
    Northants, England
    13
    Smile
    Yes! That seems to worked. Thank you very much ReMark, & everyone else who've helped.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,457
    It's an old-but-goodie that many of us tend to forget.
    You're entirely welcomed.
  1. Setup for custom profile to open each time Cad Opens
    By Proctor in forum AutoCAD General
    Last Post: 2nd Aug 2012, 01:17 am
  2. Help opens when starting Autocad 2011
    By Diedesigner in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jan 2011, 11:04 am
  3. Autocad opens in a new program every time
    By bigmaz in forum AutoCAD General
    Last Post: 25th Oct 2010, 11:24 am
  4. civil 3d opens up in autocad architecture
    By addesigns in forum AutoCAD General
    Last Post: 22nd Jun 2010, 04:51 am
  5. AutoCAD opens Excel when opening dwg with links
    By dwilcox13 in forum AutoCAD General
    Last Post: 3rd Nov 2009, 05:23 pm
