Without seeing your model I'm not sure why its not working. The part looks simply enough so I created a video showing how to use curve driven pattern. Does this help?
http://youtu.be/a-HyN1SN2i8
I try to make a timing belt. It sounds easy, but the Curve Driven Pattern feature has its own mind.
I have a Composite curve (the blue one) and a boss (green). The Curve driven pattern should multiply the boss along the curve. I clicked all the checkboxes, I tried all the combinations but this is the best I get. Can anybody help me please?
It's nice to be nice, but sometimes is nicer to be evil!.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
Certified SolidWorks Expert -Advanced Surfacing, Mold Tool, Weldments, Drawing Tool and Sheet Metal Specialist
http://www.solidworkslessons.info/
Many thanks for answering me.
As you said, it is a simple task. I worked almost in the way presented in that video, except you used a sketch as pattern path.
This morning I recreated the timing belt, and I got it well. As path I used again a Composite Curve created from the edges, exactly as previously,- except this time it worked well. I don't know what the problem was (other that I don't have enough experience with SW), but now I got it solved.
Thanks again.
