Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Use _DIMASSOC=2
    Sometimes you need to use Dimension Update after.
  2. #12
    Full Member
    AutoCAD 2004
    Jul 2012
    28
    not moving in model space just unlocking the viewport and shifting the drawing in it either left or right or up/down, no adjusting of the scale or anything like that. Usually its just because ive placed the drawing to close to the edge of the paper so i cant fit a dimension in clearly enough or something. Im thinking ill need probably the standard top, front, right views for my drawing.
  3. #13
    Full Member
    AutoCAD 2004
    Jul 2012
    28
    SLW210 what exactly does that command do?
  4. #14
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Makes dimensions associative.
  5. #15
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,137
    Quote Originally Posted by mgervais View Post
    Associative dimensions are attached to the geometry which they describe.
    If you later need to move the entities in Modelspace, or through your Viewport, the dimensions will move with them.
    If you do use associative dimensions then you create your dimstyle with primary units scale of 1.
    The appropriate scale factor is then automatically applied by the program, by using the scale of your viewport.
    When creating associative dimensions turn off your NODE osnap. You need to be very careful to ensure that
    you are snapping to the GEOMETRY, not another dimension node, for instance, or your associativity won't work.
    If you later need to modify your modelspace entity by stretching, because the length of a beam has changed?
    Then the dimension, being associatively attached to vertices at the ends of the element will reflect in real time the new length.
    Still remember to lock your viewports once you have them how you want them.
  1. 2 UCS icon in paperspace, sth is wrong!?
    By khoshravan in forum AutoCAD General
    Last Post: 6th Jul 2011, 08:18 pm
  2. WRONG DISASSOCIATED DIMENSIONS in REF-Edit
    By an3rocas in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Feb 2010, 08:39 pm
  3. Is it possible to create associative, PaperSpace dimensions using VBA
    By ginak in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jul 2009, 09:32 pm
  4. dimensions in paperspace using VBA
    By paul73 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Oct 2008, 10:27 pm
  5. Dimensions disappear in Paperspace/Layout
    By speedily in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th May 2008, 04:13 pm
