Results 1 to 7 of 7
    Full Member
    Inventor 2011
    Apr 2012
    27
    Default Alignment of Sketch with Grid; Alignment of Model with View Cube
    Hi... I'm working with Inventor 2011. I received a part file from someone, and notice that when in Sketch mode, the part is not aligned as I want it to be. That is, the horizontal and vertical lines of the sketch are not aligned with the horizontal and vertical lines of the grid.
    As well, when in Model mode,the View Cube is not aligned with the part as I want it to be. The "Front View" that the cube calls out is not orthagonal in relation to the part.
    I can think of a few ways to address these problems, but I would suggestions as to what the most efficient ways might be.
    I can attach a file if my question is not clear.
    Thanks!
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Quote Originally Posted by JillAW View Post
    ...I can attach a file if my question is not clear.
    Attach the file here.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Junior Member
    Inventor 2011
    Aug 2012
    11
    A little lateral thinking should get the job done. Firstly open the sketch. Find a corner point of your sketch and draw a horizontal line extending from it. Next use the dimension tool to find out what angle the line that should be horizontal is in relation to the line you have just drawn ( use the copy command if it is a long decimal. )Next use the modify > rotate command. Select a box around the entire sketch, next select the first corner point from before as the center point. Then just paste the angle into the angle box. Note you may have to make the angle negative , or use a little addition ie. 90 + 7.5564445 depending on how you took the original dimension.
    In terms of model view, just rotate the view how you like, right click the home icon in the corner of the view cube > set current view as > front.
    Hope this helps
    Full Member
    Inventor 2011
    Apr 2012
    27
    A belated 'thank you' for your responses. Psylencer-- this did help!
    But a lingering question remains... (next post)
  5. #5
    Full Member
    Inventor 2011
    Apr 2012
    27
    Default Alignment of view cube and orthagonal front view of model
    Let's say I get a part file from someone (please see attachment) and I want what the view cube is calling 'front' to be orthagonal to the 'front' of the model (see attached). That is, I want 'front' to be a square-on, orthagonal view. How best to align the model to achieve this?
  6. #6
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Step one
    Step 2
  7. #7
    Full Member
    Inventor 2011
    Apr 2012
    27
    I was unaware of the 'View Face' command (though embarrassingly, the icon's right in front of me). THANK YOU!
  1. Profile View Rotation/Alignment
    By traumathecat in forum Civil 3D & LDD
    Last Post: 5th Aug 2011, 05:18 pm
  2. Section view for an alignment?
    By cht13er in forum Civil 3D & LDD
    Last Post: 13th Jul 2011, 10:11 pm
  3. View alignment from sheet to sheet
    By ska67can in forum Autodesk Inventor
    Last Post: 12th May 2011, 08:12 pm
  4. Solidworks Drawing view alignment
    By vsolo in forum SolidWorks
    Last Post: 3rd Oct 2010, 10:24 am
  5. Alignment
    By CAD<LIFE in forum Autodesk Inventor
    Last Post: 19th Jun 2007, 02:25 pm
