Are you tracing an existing 3D Model perhaps?
If so, there are a number of options which will create a 2D representation of your 3D entity automatically,
including differentiating between visible and hidden lines.
Some of objects that I draw have partly hidden lines. Basically I can create two lines and then set one to be solid and the other one to be hidden. But may I know any faster way to do that?
Thanks![]()
No. I am trying to create 2D layout![]()
If you are just creating a new 2D drawing from scratch, there are not too many ways to help with this.
I wouldn't bother switching between layers as I draw these lines (I assume that you are drawing your visible and hidden lines on different layers?).
In my case I would draw all of the lines on the STEEL layer (which has continuous linetype set, by layer), then I would select all of the ones which should be moved to STEEL HIDDEN
(with linetype HIDDEN defined, by layer) and change their LAYER in QUICK PROPERTIES or PROPERTIES.
