Please check the advices from this tutorial.
I have a list giving chainages and respective coordinates of a road alignment. I need to prepare a table with four columns for the Chainage, X value, Y Value and Remark. I used to convert these with 'rtos' and put them on columns but has seen some other elegant wayn this forum. But that table does not give the colunms I need. Can someone give a clue?. The list is given below:
Thanking in advance.Code:(setq l '((0.0 (-108.124 81.3947 0.0)) (20.0 (-88.6807 86.0816 0.0)) (40.0 (-69.2377 90.7684 0.0)) (60.0 (-49.7946 95.4553 0.0)) (80.0 (-30.3515 100.142 0.0)) (100.0 (-10.9085 104.829 0.0)) (120.0 (8.53462 109.516 0.0)) (140.0 (27.9777 114.203 0.0)) (160.0 (47.4208 118.89 0.0)) (180.0 (66.8638 123.577 0.0)) (200.0 (86.3069 128.264 0.0)) (220.0 (105.75 132.951 0.0)) (240.0 (125.193 137.637 0.0)) (260.0 (144.636 142.324 0.0)) (280.0 (164.079 147.011 0.0)) (300.0 (183.522 151.698 0.0)) (320.0 (202.965 156.385 0.0)) (340.0 (222.408 161.072 0.0)) (360.0 (241.851 165.759 0.0)) (380.0 (261.295 170.446 0.0)) (400.0 (280.738 175.133 0.0)) (420.0 (300.181 179.82 0.0)) (440.0 (319.624 184.506 0.0)) (460.0 (339.067 189.193 0.0)) (480.0 (358.51 193.88 0.0)) (500.0 (377.953 198.567 0.0)) (520.0 (397.396 203.254 0.0)) (540.0 (416.839 207.941 0.0)) (560.0 (436.282 212.628 0.0)) (580.0 (455.725 217.315 0.0)) (600.0 (475.168 222.002 0.0)) (620.0 (494.611 226.688 0.0)) (640.0 (514.054 231.375 0.0)) (660.0 (533.498 236.062 0.0)) (680.0 (552.941 240.749 0.0)) (700.0 (572.384 245.436 0.0)) (720.0 (591.827 250.123 0.0)) (740.0 (611.27 254.81 0.0)) (760.0 (630.713 259.497 0.0)) (780.0 (650.156 264.184 0.0)) (800.0 (669.599 268.871 0.0)) (820.0 (689.042 273.557 0.0)) (840.0 (708.485 278.244 0.0)) (860.0 (727.928 282.931 0.0)) (880.0 (747.371 287.618 0.0)) (900.0 (766.814 292.305 0.0)) (920.0 (786.257 296.992 0.0)) (940.0 (805.701 301.679 0.0)) (960.0 (825.144 306.366 0.0)) (980.0 (844.587 311.053 0.0)) (990.275 (854.575 313.46 0.0)) (1000.0 (864.029 315.743 0.0)) (1020.0 (883.45 320.518 0.0)) (1040.0 (902.809 325.543 0.0)) (1060.0 (922.054 330.982 0.0)) (1080.0 (941.127 336.999 0.0)) (1086.27 (947.062 339.035 0.0)) (1100.0 (959.986 343.655)) (1120.0 (978.7 350.715)) (1140.0 (997.263 358.162)) (1160.0 (1015.67 365.993)) (1180.0 (1033.91 374.203)) (1200.0 (1051.97 382.79)) (1220.0 (1069.85 391.75)) (1240.0 (1087.54 401.079)) (1260.0 (1105.04 410.772)) (1280.0 (1122.33 420.827)) (1300.0 (1139.41 431.238)) (1320.0 (1156.27 442.001)) (1340.0 (1172.9 453.111)) (1360.0 (1189.29 464.563)) (1380.0 (1205.45 476.354)) (1400.0 (1221.36 488.477)) (1420.0 (1237.01 500.927)) (1440.0 (1252.4 513.699)) (1460.0 (1267.53 526.788)) (1480.0 (1282.38 540.188)) (1500.0 (1296.95 553.893)) (1502.84 (1298.99 555.867)) (1520.0 (1311.02 567.884 0.0)) (1540.0 (1324.72 582.453 0.0)) (1560.0 (1338.05 597.367 0.0)) (1580.0 (1351.12 612.502 0.0)) (1598.84 (1363.33 626.861 0.0))))
Aloy
Regards,
Mircea
AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
Thaks Mircea,
This appears to be one way. I need to study a bit on Vlisp and then modify the program appropriately.
Regards,
Aloy
Aloy .
This sub-function would help you to reform the list to appended list to become much easier to set the value after converting it to a string to a table .
Good luck .
Code:(defun AppendList (l / i n lst) (setq i -1) (repeat (length l) (setq lst (cons (list (car (setq n (nth (setq i (1+ i)) l))) (car (cadr n)) (cadr (cadr n)) (caddr (cadr n)) ) lst ) ) ) lst )
- When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
Or simply:
Code:(mapcar '(lambda ( x ) (cons (car x) (cadr x))) l)
Lee Mac Programming
Just another Swamper
LeeMac,
Yes, the lambda fuction did the trick. I was able to make use of the existing routine for polyline coordinates without reinventing the wheel and without drawing the polyline. I could use my list, l. given above. However as you will observe there is a Z coordinate aslo at some places and the function coverted that also where ever Z exist and put it in the fourth colunm. That also shows that the polyline table can be extended to many more columns.
Is there a way of shutting off the Z value when generating the list l ?.
Thank you for the help.
Aloy
Tharwat,
The function gave an error message. May be it needs a bit of modification to prepare the sub liist.
Regards,
Aloy
Mircea,
I could not make use of the tutorial as the polylines are closed ones and the solution looks a bit more comlex than in the case of open polyline given above.
Regards,
Aloy
