Results 1 to 5 of 5
    Full Member caddcop's Avatar
    caddcop's Computer Details
    WinXP
    Lenovo ThinkPad Laptop - Dual Screens on Docking Station
    Dell and Viewsonic 22' Widescreens
    Civil
    caddcop's Discipline Details
    CADD Manager - Civil/Survey
    Civil
    Working with Land Desktop 2008 and 2009, Civil 3D 2009, 2010, 2011, 2012 & 2013
    Land Desktop 2009
    Sep 2009
    Maryland (DC Suburbs)
    94
    Default Import Mixture of Alpha Numeric Points - Use point numbers when numeric?
    Is it possible in Civil 3D to import an ASCII list of points, where some points have alpha numeric names and other are simply numeric, and have the numeric names used as the point numbers?
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Doesn't seem that hard just throw it into excel first and change a bit if you use PENZD
    point number
    easting
    northing
    elevation
    description
    1002,123.45,567.89,123.45,1002
    1002,123.45,567.89,123.45,tree05
    only problem may be that numeric codes are read as library item so
    1002,123.45,567.89,123.45,PT1002 would fix
    WinXP
    Civil
    Civil
    Land Desktop 2009
    Sep 2009
    94
    I ended up changing my report that generates the list to remove the alpha characters. I did not add error checking to prevent duplicate points, but this was the first time in many years that I had someone use alpha numeric point names.
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    One of the biggest bug bears with Civ3d is setting up libraries/styles there is no easy dump to text file re import etc It would make it so much easier to do what you wanted even to simply add extra codes.
  5. #5
    WinXP
    Civil
    Civil
    Land Desktop 2009
    Sep 2009
    94
    Depending upon your version -2010 or 2011, there is such a tool. Actually, there might be more than one, but the one I just found and really like is:
    http://inmotioncon.com/c3dstgs.shtml
    The file it creates for import or export has an extension of csgz - and can be opened with jZip or 7Zip or any of the other zip file clones. Then, in it are DWG files, and XML file and a CSG file - which also happens to be an XML file.
    With the right tools, you should be able to copy and paste items within it and rename the copies to create many new styles very quickly. I use Notepad++ with the XML tools add-in, and have great success with editing XML files. But I have only recently learned of this tool so I have not had much of a chance to experiment. If you go the Notepad++ route, make sure you add the new file extension to its XML styler so it will display the syntax highlighting automatically.
    Last edited by caddcop; 29th Aug 2012 at 01:28 pm. Reason: Additional information.
  1. Can't import all points into dwg
    By poophead in forum Civil 3D & LDD
    Last Post: 12th Jul 2012, 04:38 pm
  2. Importing survey points with numbers in AutoCAd 2011 Map
    By paduroiul in forum Student Project Questions
    Last Post: 4th May 2012, 04:11 am
  3. Civil 3D-Exporting Cogo Points with Station Numbers
    By Keith_1978 in forum Civil 3D & LDD
    Last Post: 1st Jul 2011, 12:28 am
  4. Creating alpha-numeric content for production
    By Dr Pepper in forum AutoCAD Beginners' Area
    Last Post: 12th Apr 2011, 10:08 am
  5. naming points with consecutive numbers....
    By muss in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jul 2005, 10:22 am
