Polstar Posted August 22, 2012 Share Posted August 22, 2012 Hi all, it is ages since i have the time to be learning Revit!!! How is it best to insert windows that aren't in the standard libraries? I mostly deal with domestic extensions (I know, I know, Revit is like cracking a nut with a hammer for this type of work, but...), and each existing windo is slightly different in size and fenestration. I am looking for the easiest way to create each window as individuals. Is it possible to load a certain standard window (closest match) and modify it (only after duplicating obviously!)? Or is the best way to introduce a curtain system and add mullions where required? I had a quick go with the latter and i found that the frames (mullions) don't clean up well??? Any ideas?... Quote Link to comment Share on other sites More sharing options...
JRevit Posted October 30, 2012 Share Posted October 30, 2012 you could make a multi-family window with a lot of variables to control frame width etc. Quote Link to comment Share on other sites More sharing options...
