Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member
    AutoCAD 2008
    Dec 2007
    130
    Default VBA: Number formatting
    Hey all,
    I appreciate this is more VB than VBA but its an AutoCAD tool i'm making so posting it here too..
    Trying to creating a tool that inserts datum lines in a drawing which is fine, the only issue is the formatting of the attribute to display within the block (see the bold part of the code below). I'm trying to display the datum level as "+0.000" which is fine for most input but if the number has any trailing zeros, they are not displayed. I've searched high and low on the net for this and have tried everything i have found but still no results..
    (All variables in the code have been declared and no errors occur at run-time, just not the correct display:
    ie: "+6.800" displays in the block as "+6.8" and "+8.760" displays as "+8.76")
    Code:
    '************ GROUND FLOOR ***************
    GROUND:
    ' Check if GROUND is selected..
    If LVLtxtGRND.Text = "" Then
        GoTo FIRST
        Else 'If a value is shown then insert the block..
        LVLvalueGRND = LVLtxtGRND.Text
        ' Draw LINE for level..
        LineGRNDstart(0) = 0: LineGRNDstart(1) = LVLvalueGRND: LineGRNDstart(2) = 0
        LineGRNDend(0) = LINEend: LineGRNDend(1) = LVLvalueGRND: LineGRNDend(2) = 0
        Set LINEgrnd = ThisDrawing.ModelSpace.AddLine(LineGRNDstart, LineGRNDend)
        LINEgrnd.Layer = "X-Levels"
        ' Insert LEVEL Block..
        LVLinsertGRND(0) = 0: LVLinsertGRND(1) = LVLvalueGRND: LVLinsertGRND(2) = 0
        Set LVLblockGRND = ThisDrawing.ModelSpace.InsertBlock(LVLinsertGRND, "Level", 250#, 250#, 250#, 0)
        LVLblockGRND.Layer = "X-Notes"
    ' Display level figure on screen..
    LVLvalueGRND = LVLvalueGRND / 1000   'Get it into metres, no mm..
    LVLvalueGRND = Round(LVLvalueGRND, 3)
    LVLvalueGRND = Format(LVLvalueGRND, "0.000")
    AttribZ = LVLblockGRND.GetAttributes ' Get Block attributes..
    For CountX = LBound(AttribZ) To UBound(AttribZ)
        Select Case AttribZ(CountX).TagString
        Case "LEVEL"
            AttribZ(CountX).TextString = PlusChar & LVLvalueGRND & " " & " " & DESCcomboGRND.Text
        End Select
    Next CountX
    'On Error Resume Next
    '    MsgBox Err.Number & vbCr & Err.Description, vbExclamation, "Error:"
    End If
    Any ideas? This is twisting my melon now grrr
    Cheers,
    PaulRenegade @ hardwiredstudios..
    XP Pro / AutoCAD 2007 : Pentium Core 2 Q6600 Quad Core : ASUS P5N-E SLI Motherboard : 4GB DDR2 RAM : 2 x SLI NVIDIA 8500GT SLi 1024MB DDR2 PCI-Express Graphics Cards
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    181
    Baffling. Shouldn't need to do this but as a real kludge until something better comes along you could compare the INSTR position of the decimal point with the string's length and append any needed zeroes. If no decimal point append ".000" to the string.
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, Vista and XP Pro
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    866
    Quote Originally Posted by hardwired View Post
    Code:
    To get the trailing zeros you need to rewrite the above line so it reads:
    Code:
    LVLvalueGRND = Format(LVLvalueGRND, "0.##0")
    I hope that helps
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    181
    Quote Originally Posted by Tyke View Post
    Code:
    I hope that helps
    If that works we all learn something. I hope someone can explain why it should work, either by example or by arguing from first principles.
  5. #5
    HP Z400 Workstation
    8 GB
    Multi-disciplinary
    Multi-disciplinary
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    866
    I've used it a lot for this very situation in both VBA and VB .NET and it works fine. It was a real pain in the backside for me until I found the solution try it out and get back to us with your result.
  6. #6
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    181
    It works for sure. Sorry, I was just idly curious as to how you came upon the answer - it's not well documented by MS e.g:
    http://msdn.microsoft.com/en-us/libr...(v=vs.90).aspx
  7. #7
    HP Z400 Workstation
    8 GB
    Multi-disciplinary
    Multi-disciplinary
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    866
    Glad it worked for you hugha.
    You are right it is not very well documented and I saw a similar link to the one you just posted, after which I just experimented a bit till I got it to work. The # symbol is a standard place holder in Visual Basic, although the documentation says that "0.000" should work, but it never did for me. I have been using it regularly now for around six years. Let's hope that it works for hardwired too
    Thanks for getting back hugha and
    that we have all learned a little bit.
  8. #8
    Senior Member
    AutoCAD 2008
    Dec 2007
    130
    Hey all,
    Thanks for all your replies. I tried the '0.##0' solution, Tyke but still no luck. I think my PC doesn't like to be too negative haha. This is a real head-screwer as it seems to be working for everyone else just not me. I'll give your first solution a go, hugha and see what happens
    Cheers,
  9. #9
    HP Z400 Workstation
    8 GB
    Multi-disciplinary
    Multi-disciplinary
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    866
    I've tried out exactly the code you have on two computers, in AutoCAD 2010 and 2013 in both German and English language versions of AutoCAD, but admittedly only on a German Windows XP operating system. It works fine with your unaltered code and also with my suggestion.
    What OS do you have? 32 bit or 64 bit? It shouldn't make any difference, but check the decimal seperator in your Regional Settings.
  10. #10
    Senior Member
    AutoCAD 2008
    Dec 2007
    130
    Hey Tyke, I've had a look at my regional settings and can't see anything else to change except figures to 3 decimal places but that didn't work anyway..
    I'm on AutoCAD 2010 on an 32-bit XP Pro machine by the way..
    Cheers,
  1. Replies: 4
    Last Post: 29th Dec 2010, 06:28 pm
  2. Formatting Help
    By TravC2121 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Dec 2009, 10:18 pm
  3. Table formatting
    By blatz.boy in forum AutoCAD General
    Last Post: 27th Jun 2008, 07:08 pm
  4. Formatting in MTEXT
    By Aries7 in forum AutoCAD Drawing Management & Output
    Last Post: 27th Dec 2006, 08:55 pm
