Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, Vista and XP Pro
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    857
    We sometimes get a conflict here as the decimal seperator on a German language OS is by default a comma and some software will only work properly when its set to a "."
    I don't honestly believe it is your problem here, but its worth a look.
    Have you tried running your program on another machine? Try to find out if its machine specific or code specific.
    As an aside, I had exactly this problem in 2007 when I wrote some VBA code and used the "0.##0" to get round the problem. Yesterday I ran the same code on a new W7 x64 machine with AutoCAD 2013 and replaced "0.##0" with "0.000" and it worked fine! It looks to be more Machine specific than anything else. After I got that result I tested on anther XP Pro x86 running AutoCAD 2010 and "0.000" worked fine there too.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
  2. #12
    Senior Member
    AutoCAD 2008
    Dec 2007
    130
    Hey all, after being booted off this site for apparently sending an advert post, I'm back
    I managed to sort my number formatting / decimal place issue with a little bit of cheating though I'm afraid. I simply converted the value to a string variable then formatted it. Its fine for what I needed but obviously not the correct way but needs must I guess..
    Thanks for all your help guys and if you find a reason why mine didn't work before, please let me know and I'll do likewise..
    Cheers,
    PaulRenegade @ hardwiredstudios..
    XP Pro / AutoCAD 2007 : Pentium Core 2 Q6600 Quad Core : ASUS P5N-E SLI Motherboard : 4GB DDR2 RAM : 2 x SLI NVIDIA 8500GT SLi 1024MB DDR2 PCI-Express Graphics Cards
  1. Replies: 4
    Last Post: 29th Dec 2010, 06:28 pm
  2. Formatting Help
    By TravC2121 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Dec 2009, 10:18 pm
  3. Table formatting
    By blatz.boy in forum AutoCAD General
    Last Post: 27th Jun 2008, 07:08 pm
  4. Formatting in MTEXT
    By Aries7 in forum AutoCAD Drawing Management & Output
    Last Post: 27th Dec 2006, 08:55 pm
