natur3 Posted August 27, 2012 Share Posted August 27, 2012 Hi all! I would like to know which of the following software can be used to generate a 3D model/surface using the key points. The key points were obtained from 4 images after spline-fitting. 1) ACIS Reader 2) AUTOCAD 3) Autodesk Inventor ( Associative Geometry Interface and Reader (Merged/sewn work surfaces are not supported. ) 4) CATIA Reader 5) CATIA V5 Associative Geometry Interface and Reader 6) Creo Elements/Direct Modeling 7) Cero Parametric (formerly Pro/ENGINEER ) Associative Geometry Interface and Reader GAMBIT Reader 9) IGES Reader 10) JT Open Reader 11) NX Associative Geometry Interface and Reader 12) Parasolid Reader 13) Solid Edge 14) SolidWorks Associative Geometry Interface and Reader 15) STEP Reader or any other CAD software whom models can be used in ANSYS 14.0. Thank you all for your help!! Best Regards, natur3 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 28, 2012 Share Posted August 28, 2012 Sounds like student homework have'nt you allready answered the question. Quote Link to comment Share on other sites More sharing options...
natur3 Posted August 28, 2012 Author Share Posted August 28, 2012 Sounds like student homework have'nt you allready answered the question. Thank you for your prompt reply! Yea, I am currently doing a simulation project in which I had to first generate a 3D model/surface from the key points using one of the software above. Than importing the 3D model/surface into ANSYS 14.0 to do the simulation. I have answered the question? All the software including, ANSYS 14.0, that I stated above are able to generate the 3D model/surface from key points? I have never touch AutoCad since 6 or 7 years ago. Had lost touch with it. Best Regards, natur3 Quote Link to comment Share on other sites More sharing options...
