Results 1 to 3 of 3
    Full Member
    Civil 3D 2013
    Mar 2012
    49
    Default Right-Click Customization Issue
    Hello,
    So when using C3D, I have my right-click setup so that when I click on an object, say a multi-leader, surface, etc, a long menu pops up with object-specific options. Such as multi-leader styles and scales, pipe network options, etc.
    So today, AutoCAD decided to be lazy and not show that menu. I've tried turning off the R-C customization, then turning it back on, switching the custom options around, applying, then setting them back to the way I had them, starting a new drawing, restarting CADD, and finally restarting my computer. NOTHING.
    This has happened to me several times in the past and it just starts working properly again at some point. To draft, modifying C3D objects, without the r-c menu is such a time consuming PITA.
    Thoughts?
    Full Member
    Civil 3D 2013
    Mar 2012
    49
    N/M.
    I was going through the Options tabs and found the "Noun/Verb Selection." I remembered someone talking about this on this forum or another. It was unchecked, don't know how. I checked the box and voila!
    Senior Member Squirltech's Avatar
    Squirltech's Computer Details
    Windows 7 Enterprise, Service Pack 1
    @xi
    32.0 GB
    230 GB
    Dual Dell 21"
    Surveying
    Squirltech's Discipline Details
    Senior Survey Technician
    Surveying
    Civil 3D 2009
    Oct 2010
    30 15' N, 97 44' W
    162
    T. Nelson
    Sr. Survey Technician
    http://www.saminc.biz
    "The only thing left to do is EVERYTHING!" - Jesse James
  1. Right click customization issue
    By Proctor in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 10th Oct 2011, 03:55 pm
  2. Right click customization??
    By desiree in forum AutoCAD General
    Last Post: 21st Dec 2009, 04:03 pm
  3. right-click mouse customization
    By StevenNoppe in forum AutoCAD Beginners' Area
    Last Post: 29th May 2009, 12:40 pm
  4. Right Click Customization
    By CADDict in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jan 2008, 01:06 pm
  5. Right Click Menu customization
    By jtlinx in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Oct 2005, 10:14 pm
