Results 1 to 8 of 8
    Junior Member
    Civil 3D 2010
    Jan 2011
    11
    Default MPOLYGON Button?
    Hi all,
    I am running Civil 3d 2010. I am wondering if there is a MPOLYGON button. I will be making a lot of mpoly's shortly and a button would be convenient.
    I have seen it in CAD MAP under the "Create" ribbon, but I cant find it in Civil.
    Thanks!
    Senior Member Emigrato's Avatar
    not applicable
    Sep 2011
    116
    Why don't you modify an unused icon of your drawing set?
    Type in CUI, then change as _MPOLYGON the command associated to the Helix, for instance.
    Full Member
    Civil 3D 2011
    Aug 2011
    99
    Just add the "MPOLYGON" command from the CUI into your workspace. Find it in the command list and then Drag and drop it into which ever tab you want it to be in.
    Or you could create an alias for the command, such as "MP". Easy to type.
    Junior Member
    Civil 3D 2010
    Jan 2011
    11
    Excellent, in CUI I looked up Helix and on the macro line I enterend _MPOLYGON and that worked great so thank you Emigrato.
    As far as the click-and-drag method that was not working for me it would not allow me to drag anything anywhere.
    I dont know if this requires another post but Bill mentioned creating an alias command? How is that done?
    Thanks so much resolving this issue
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,119
    You would have to edit your acad.pgp file which can be done from with AutoCAD via the Ribbon. The Manage tab > Customization panel > Edit Aliases. Put your new command aliases at the end of the file where noted.
  6. #6
    Senior Member
    AutoCAD 2012
    Jun 2012
    346
    Quote Originally Posted by Gambit View Post
    Via the acad.pgp file. In AutoCAD 2012, Ribbon: Manage>Customization>Aliases; Pull Downs: Tools>Customize>Edit Program Parameters (acad.pgp).
    At the end of the pgp file, add
    Code:
    MP,         *MPOLYGON
    Save AND exit file; then type Reinit at the command prompt; check PGP File; click OK. Try entering MP at the command prompt and you should get MPOLYGON.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,119
    See post #17 by nestly in this thread re: acad.pgp and editing.
    http://www.cadtutor.net/forum/showth...light=acad.pgp
  8. #8
    Full Member
    Civil 3D 2011
    Aug 2011
    99
    in order to drag the command into a tab, you have to have the entire order expanded, even the Rows. Then drag the command into there. Takes a few times to get used to it.
    I would not recomend changing the macro of a command. Down the road you may have to make a helix, and find out that you changed your button and not remember what the old Macro was.
    The Alias is pretty fool proof, just make sure that you dont have any duplicate shortcut commands. You will implode the universee if that happens.
  1. F1 Button
    By toddsyoung in forum AutoCAD General
    Last Post: 9th Dec 2010, 01:46 pm
  2. Add Button
    By resto in forum AutoCAD General
    Last Post: 7th Oct 2010, 11:27 am
  3. Middle button pan and right button object drag doesnt work
    By henryhavinci in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 26th Mar 2009, 06:27 pm
  4. button help
    By Brian_sme in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Oct 2007, 05:09 pm
  5. Setting middle mouse button as F3 button
    By alerch in forum AutoCAD Drawing Management & Output
    Last Post: 1st Aug 2006, 10:04 pm
