Results 1 to 6 of 6
Thread: Layer States
    Junior Member
    not specified
    May 2006
    10
    Default Layer States
    Is it possible to assign layer states to shortcut keys? Seems like something that would be reasonable to do but i am unable to find any way to do it.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,558
    Assuming you have a layer state named "special", the following lisp code will restore it, using the shortcut RS
    Code:
    (defun c:rs ()
      (command "._layer" "_A" "_R" "special" "" "")
    R.K. McSwain
    CAD Panacea | twitter
    Junior Member
    not specified
    May 2006
    10
    alright i'm still pretty new with lisps, and i can type that code in and it works, but is there anyway to save that kind of lisp to the file so everytime i open the file those key codes are there?
    Senior Member
    not specified
    Feb 2006
    Guelph, Ontario
    436
    copy the text from the code above and paste it into notebook. Save that file as "filename.lsp". Save this file into the support folder of autocad. Now go into AutoCAD and type in "appload" at the command prompt. In the "Startup Suite" click on Contents. Now click on add and search through and add "filename.lsp".
    Mike
  5. #5
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,558
    ...and even more details here:
    http://cadtutor.net/forum/viewtopic.php?t=2942
    R.K. McSwain
  6. #6
    Junior Member
    not specified
    May 2006
    10
    worked like a charm, you guys are good
