Results 1 to 3 of 3
    Forum Newbie
    AutoCAD LT 2013
    Aug 2012
    1
    Default Layer control by viewport in paper space
    This only happens from time to time. I have a sheet set up with multiple viewports. I double click in one viewport, type LAYER, and the layer dialog appears but my viewport has changed.
    Anyone else have this problem and more importantly have a solution?
    Thanks.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    11,733
    What changes?
    Can you post some images or even better the .dwg?
    Full Member
    AutoCAD LT 2009
    Jun 2009
    31
    click in the viewpoint and use the command ucsfollow and set the variable to 0. Try that.
  1. Bring Paper Space object through Viewport into Model Space
    By karenreeves in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Nov 2011, 08:58 pm
  2. SSM, Views, and Viewport Layer Control
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 21st Apr 2011, 04:17 am
  3. How to Freeze paper space dimension layer in model space
    By david1954 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th May 2010, 04:16 pm
  4. Layer Viewport control question...
    By VIC842 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Nov 2007, 04:59 pm
  5. VIEWPORT LAYER DISPLAY CONTROL
    By muirarchitects in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jun 2006, 06:09 pm
Tags for this Thread
