Results 1 to 4 of 4
    Junior Member
    Environmental
    3ds Max Design 2013
    Nov 2005
    UK
    21
    Default Edit poly tightening edges
    Hi,
    A bit of an odd query and I think I probably know the answer but wanted to just check whether there was a better way to do this. I have this shape
    Which smooths like this
    I want sharp edges and I know I need to add extra edge loops to achieve this such as
    But I don't really want the full edge loop to carry along the rest of the shape as this causes sharp creases along these edges. Is there any way round this? The only thing I can think is to create triangles at each corner rather than quads
    But I thought that was a bit of a no-no? I want to try and keep my model clean and correct, is there a better way to achieve this?
    Cheers
    James
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,427
    You just need more geometry in order to create something like this. The attached file was created in Max 2011. You didn't mention what version of Studio Max you are using and it's not listed in your user profile, so you may or may not be able to open my file, but check it out if you can. Otherwise, here are some screenshots, with and without Turbosmooth applied.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    Junior Member
    Environmental
    3ds Max Design 2013
    Nov 2005
    UK
    21
    Ok this kind of makes sense, so I just need to add more edge loops in the areas I want to tighten? I will give this a go... thanks!
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    3ds Max 2011
    Feb 2006
    Southern California
    8,427
    Quote Originally Posted by james120479 View Post
    Yes, you just need more geometry around those corner areas. No need to add edge loops in areas where it's not needed.
  1. Lazy Typist Text Edit:<Mid Sentence Edit>
    By pBe in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2011, 01:38 pm
  2. Lisp edit - Area by poly
    By Peu in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Apr 2011, 08:29 pm
  3. 3d poly to csv
    By bucks87 in forum AutoCAD General
    Last Post: 11th Dec 2009, 07:05 pm
  4. edit ground in view edit corridor sections
    By ikapo in forum Civil 3D & LDD
    Last Post: 10th Apr 2009, 10:24 am
  5. 3D Poly
    By spursnutter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Nov 2008, 03:41 pm
