If no one knows how to help me can you refer me to other references. I have tried the help through Autodesk and several textbooks (the texts are for 2011 and I am using 2012)
Thanks
Hi All,
When I try and add a second revision tags to a .idw file the old revision tags automatically update to the most recent tag identifier. So I have previously revised the drawing with revision "A" and now I am revising the drawing again. When I try to put in Revision tag "B" some of the "A"'s become "B"'s.
Sorry if that is not clear.
Thanks
Thanks
Which button did you use to add rows to your rev table?
I suspect you'll find a clear correlation between which button you used to add the row, and which rows are getting their number changed.
Thank you Bishop. I have never noticed the difference between the two options before.
