Did you try the THICKEN command?
Hello!
I have a 3D geometry in .dwg format ... it is a part of an umbrella membrane structure (see the attached pic.)
This geometry is divided into litte pieces. Each piece is a '3D surface' object
I need to give this umbrella a thickness!
I tried Extrude command; Error! the surface object should be planner
I tried surface offset command as explained here
http://autocadinsider.autodesk.com/m...ocad-2011.html
did not work cuz my object is not a planner surface nor a extruded surface
so... what to do experts?!
Thanks a lot in advance!
Surface before using THICKEN command on left. After using THICKEN command on right (now it is a solid).
I'll assume that ^ ^ ^ means you are pleased with the results. Good.
Here are some of those objects [Check the attachment]
The surface I used in the example was a simple flat one. I'll take a look at your part.dwg when I get a chance.
Welcome to the forum.
How did you create the 3D Faces in your drawing?
