+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Super Member Bill Tillman's Avatar
    Using
    AutoCAD 2013
    Join Date
    Oct 2008
    Location
    Miami, FL
    Posts
    870
    Default Part Imported from AutoCAD is Missing Holes
    I drew the attached part in AutoCAD 2012. Then I imported it into Inventor. All was well but then I noticed I had left off the holes near the center of the length of the extrusion. I went back to AutoCAD and made the correction but then when I imported it into Inventor it was still missing the exact same holes which I revised for. I tried this several times but each pass the part would come in and the 8 holes near the center of the length were always missing in Inventor. It's like Inventor was pulling something from cache on the part and would not let the new changes from AutoCAD come through.
    Can anyone else import this and let me know if the same thing happens to you?
    It's deja vu, all over again.
  2. #2
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,904
    Default
    Looks identical in AutoCAD and Inventor to me.
    Attach you ipt file here.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  3. #3
    Using
    AutoCAD 2013
    Join Date
    Oct 2008
    Location
    Miami, FL
    Posts
    870
    Default
    Thanks again JD. I can't figure this one out. I will try it again in the morning and then if it happens again I will send the ipt file over. The darned thing is that I'm starting to get pretty good at working in Inventor and I already edited the part files for this part as well as it's mirror image to add the other holes (all 16 of them). It took me a little while tonight to start using planes and projecting geometry to drill these holes. There are so many faces to these parts that the only efficient way to drill the pattern was to establish a plane parallel to the major axis, project one of the existing hole centers and do my sketch for the hole patterns there. The trick is not to always dill through otherwise in some locations I end up taking metal out of the gasket race which is no big deal until they start machining. I don't want to make anymore work for the CNC guys than needed.
Similar Threads
  1. Help me put holes in this part
    By ChrisWatkins in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Mar 2012, 04:00 pm
  2. How to change color on imported STEP part
    By EvanH in forum SolidWorks
    Last Post: 24th Sep 2010, 05:34 pm
  3. Imported Autocad geometry won't extrude
    By momentumbob in forum Autodesk Inventor
    Last Post: 1st Sep 2010, 07:54 pm
  4. Missing parts of imported JPGs - ACAD 2005
    By Nathan_SF in forum AutoCAD General
    Last Post: 7th Oct 2008, 04:50 pm
  5. imported autocad model
    By sara in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Jun 2005, 02:22 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
