Type ID on the command line then select the point...![]()
Hi All,
Please help me to find the coordinate of a point at a given distance before the first vertex of a polyline through autolisp.
Hope its clear, if not please ask i'll attach a sample drawing.
Thanks and Regards
Aaryan.
Thanks kaizen for your reply, but i want to know it through autolisp.
Below I've attached the drawing for the reference.
Drawing5.dwg
Regards
Specify a point by function (getpoint) then retrieve the variable value with functions (car) , (cadr) and (caddr) .
- When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
Thanks Tharwat,
I think I've not made it clear before. Please see my 3rd post in which i have attached a drawing for reference.
Thanks again
Regards
Okay , if you want to specify a point on an entity , you can use the function (vlax-curve-getpointatdist <entity name> <distanse>) .
if not , just read about the function polar e.g (polar <point> <angle> <distance>) .
Tharwat
Thanks You So Much Tharwat.
Here's another way:
Code:(defun _getpoint ( ent dis / der ) (setq der (vlax-curve-getfirstderiv ent (vlax-curve-getstartparam ent)) dis (/ dis (distance '(0.0 0.0 0.0) der)) ) (mapcar '(lambda ( a b ) (- a (* dis b))) (vlax-curve-getstartpoint ent) der) )Code:(defun c:test ( / e ) (if (setq e (car (entsel))) (_getpoint e 50.0)) )
Lee Mac Programming
Just another Swamper
Thank You So Much Lee Mac.
Regards
Aaryan
