byk3bep Posted September 1, 2012 Share Posted September 1, 2012 Is there a way of reversing the start and end points of a line? I have a lot of mirrored lines on my model, and so the direction (start/end) is also mirrored. This poses a problem when i export the model to another program witch has a coordinate system based on the direction of the entity (in this case a line). So i come back to the question, is it possible to change(reverse) the start/end position to already drawn (mirrored) lines? Btw i am using acad2011 Thx for your time Quote Link to comment Share on other sites More sharing options...
Murph_map Posted September 1, 2012 Share Posted September 1, 2012 yes, try the "reverse" command. Quote Link to comment Share on other sites More sharing options...
byk3bep Posted September 1, 2012 Author Share Posted September 1, 2012 thx man, that did it Quote Link to comment Share on other sites More sharing options...
khoshravan Posted July 20, 2015 Share Posted July 20, 2015 yes, try the "reverse" command. On which step this command will be used? Quote Link to comment Share on other sites More sharing options...
byk3bep Posted July 20, 2015 Author Share Posted July 20, 2015 That was so long ago that I can't for the life of me remember what was it for Note to self: post pictures and describe the end result/goal that is to be achieved Quote Link to comment Share on other sites More sharing options...
Murph_map Posted July 20, 2015 Share Posted July 20, 2015 On which step this command will be used? After the polylines are created. It works like any other edit command ie. ERASE. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 21, 2015 Share Posted July 21, 2015 When we get our field survey often joined lines are reversed and they have a linetype facing wrong way, a simple trick we do a PE pline edit pick correct direction line then join others this auto reverses them. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 21, 2015 Share Posted July 21, 2015 Or just Double-Click Polyline and Reverse option will show on Command Line or in Dynamic Input selection, you can also Right-Click a Polyline>Polyline>Reverse. Quote Link to comment Share on other sites More sharing options...
