Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member
    AutoCAD 2012
    May 2012
    78
    Default Alignment with offset and chainage Lisp
    Is it possible to make a lisp which will create a Alignment with given offset and put chainage of given meter interval. Suppose I have a polyline which 6000 mts. It is the centerline. Now I have to create a offset of 40 mt. witdth (i.e 20 mt. at right and 20 mt. at left) and put a tik mark at 100 mt interval. At each interval the chainage will increase by 100 mt. and a text will put like 0.0 km, 0.1 km, 0.2 km etc.
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Yes, it is possible for that to be done.
    Full Member
    AutoCAD 2012
    May 2012
    78
    How? I can not make it.
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,177
    Can you post a snapshot or upload a sample drawing ?
  5. #5
    Full Member
    AutoCAD 2012
    May 2012
    78
    Quote Originally Posted by Tharwat View Post
    Sure. Just check the sample.........
  6. #6
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,533
    This will help you with the offset:
    http://lee-mac.com/doubleoffset.html
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  7. #7
    Full Member
    AutoCAD 2012
    May 2012
    78
    Quote Originally Posted by Lee Mac View Post
    Thank you Lee. But I actually need the chainage with double offset.
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,533
    Quote Originally Posted by souvik View Post
    I know you do, but I can't justify the time spent writing the entire program for you on voluntary time.
  9. #9
    Full Member
    AutoCAD 2012
    May 2012
    78
    Sorry, Lee. I didn't want to insult you. I just inform you what I need. That's all.
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,177
    Try this draft ...
    Code:
    (defun c:Test (/ Text o i n k j ss in l l1 l2 sn e e1 r p pt)
      (vl-load-com)
      ;;; Tharwat 02. Sep. 2012 ;;;
      (defun Text (l l1 l2 / j i pt)
        (setq j 0
              i 0.0
        (repeat (fix (/ l 100.))
          (entmakex (list '(0 . "TEXT")
                          '(40 . 10.0)
                          (cons 1 (strcat (rtos (setq i (+ i 0.1)) 2 1) "Km."))
                          (cons 10 (setq pt (nth j l1)))
                          (cons 11 pt)
                          (cons 50 (setq r (angle (nth j l1) (nth j l2))))
          (setq j (1+ j))
      (if (setq ss (ssget "_:L" '((0 . "LWPOLYLINE"))))
        (repeat (setq in (sslength ss))
          (setq o 20.
                n 100.
                k 100.
          (if (> (setq l (vlax-curve-getdistatparam (setq sn (ssname ss (setq in (1- in)))) (vlax-curve-getendparam sn)))
                 100.
            (progn (vla-offset (vlax-ename->vla-object sn) o)
                   (setq e (entlast))
                   (repeat (fix (/ (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) 100.))
                     (setq l1 (cons (vlax-curve-getpointatdist e n) l1))
                     (setq n (+ n k))
                   (vla-offset (vlax-ename->vla-object sn) (- o))
                   (setq e1 (entlast))
                   (setq n 100.)
                   (repeat (fix (/ (vlax-curve-getdistatparam e1 (vlax-curve-getendparam e1)) 100.))
                     (setq l2 (cons (vlax-curve-getpointatdist e1 n) l2))
                     (setq n (+ n k))
                   (if (< (car (vlax-curve-getstartpoint sn)) (car (vlax-curve-getendpoint sn)))
                     (setq l1 (reverse l1)
                           l2 (reverse l2)
                   (Text l l1 l2)
                                   '(40 . 10.0)
                                   (cons 10 (setq pt (vlax-curve-getstartpoint e)))
                                   (cons 11 pt)
                                   (cons 1 "0.0Km.")
                                   (cons 50 r)
                   (setq e nil
                         i 0.0
            (princ "\n Polyline is shorter than 100.0 units long !!")
          (setq l1 nil
                l2 nil
  1. Replies: 6
    Last Post: 11th Sep 2012, 08:20 pm
  2. Road alignment drafting problem using lisp routine
    By aloy in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jun 2012, 11:47 pm
  3. Lisp for Civil 3D objects - Station from Alignment into a User Defined Property
    By Bill_Myron in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Mar 2012, 04:00 pm
  4. Horizonal Alignment Lisp Inquiry
    By runner214 in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Apr 2010, 08:50 am
  5. importing alignment points (sta,offset,elev)
    By shooter1 in forum AutoCAD Beginners' Area
    Last Post: 18th Mar 2010, 06:23 pm
