ah7391 Posted September 3, 2012 Share Posted September 3, 2012 Once again, working with viewports. I want to be able to capture only the outline of the shape I am working with when viewing it at a certain view. For example, the MIDDLE picture is my shape. LEFT PICTURE is the TOP view of my shape. RIGHT PICTURE is what I want - the OUTLINE of the top view seen in the LEFT PICTURE. Is it possible to get this "outlined" view in autocad? Quote Link to comment Share on other sites More sharing options...
MSasu Posted September 3, 2012 Share Posted September 3, 2012 Please check the SOLPROF command. (I believe that there are other options available, too, but I didn't kept up with 3D module lately) Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 Assuming you are working in 3D click into each viewport you want, then go to VIEW (top of screen) then VISUAL STYLES on drop down menu and choose between those available, ie wireframe and hidden. Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 However, MSAU's advice is probably more 'correct' and will print better without having to mess around. Let us know how you get on Quote Link to comment Share on other sites More sharing options...
ah7391 Posted September 3, 2012 Author Share Posted September 3, 2012 the SOLPROF command seems to hold a lot of promise, but I'm not too sure how to use it! I purely want an outline of the view (which is a pure TOP view of the object). I'm not sure which options to select for the SOLPROF command to get just the outline... Here's the documentation for reference: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-5345.htm,topicNumber=d0e314438 Thank you guys so much - this forum is INCREDIBLY helpful! Quote Link to comment Share on other sites More sharing options...
MSasu Posted September 3, 2012 Share Posted September 3, 2012 After call the SOLPROF command, select the solid entities and accept all options as default. After command processing is done, you will get two new layers: PH-? which retain invisible parts and PH-? for visible ones. The ? part of the name is unique for a each viewport. Just make sure that the PH-? layer and the layer(s) that store the solid(s) are set to OFF or frozen. And, very important, don't forget that the command will works only from Layouts. Quote Link to comment Share on other sites More sharing options...
ah7391 Posted September 3, 2012 Author Share Posted September 3, 2012 After call the SOLPROF command, select the solid entities and accept all options as default. After command processing is done, you will get two new layers: PH-? which retain invisible parts and PH-? for visible ones. The ? part of the name is unique for a each viewport. Just make sure that the PH-? layer and the layer(s) that store the solid(s) are set to OFF or frozen. And, very important, don't forget that the command will works only from Layouts. Hmm, I am following exactly what you said, but I seem to get the same image as the top view as a 2D layer, NOT the OUTLINE (see attached picture). I'm not getting the "3.png" image I want... Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 3, 2012 Share Posted September 3, 2012 Welcome to the forum. Whoops Mircea beat me to it! If you want to use SOLPROF, remember that it only works on 3d Solids. If you don't want to see the HIDDEN LINES displayed, then accept all of the default commandline options, and turn off the PH- layer after you run it. SOLPROF Select objects: Specify opposite corner: 268 found Select objects: Display hidden profile lines on separate layer? [Yes/No] : Project profile lines onto a plane? [Yes/No] : Delete tangential edges? [Yes/No] : The SOLPROF command will create two new layers. One of them will have the PV- prefix, the V stands for VISIBLE. The other new layer name will have the PH- (for HIDDEN) prefix. Each of the layers will contain a block with all of the VISIBLE or all of the HIDDEN lines. If you want to EXPLODE them, you can then put them on whatever layer you want, and they will take on the layer attributes of that layer. Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 Freeze the PH layer (H for hidden) and only have the PV (V for visible) layers on. You should go into the layer properties manager thingy and asign a relevant linetype and colour to the hidden layers too Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 Dadgad beat me to it! Quote Link to comment Share on other sites More sharing options...
ah7391 Posted September 3, 2012 Author Share Posted September 3, 2012 Haha Well that's the thing - the line I'm trying to get rid of ISN'T a HIDDEN line. It is a visible line that I want to simply get rid of. Maybe people don't understand what I want - I want a PURE OUTLINE of the PERIMETER of object at a certain view. I want to get rid of any internal lines and just want the PURE PERIMETER as seen in picture 3. Does that make sense? My view is also set to hidden anyway so solprof wouldn't seem to do much anyway... Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 As Dadgad says explode the block created by SOLPROF then you can trim as neccessary. You may also want to have a play with FLATSHOT. Some good tutorial vids on youtube...have a look Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 By the way, FLATSHOT won't give you a perimeter of the shape you posted, it will give you a block of all the 2D geometry. Explode and trim...... Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 3, 2012 Share Posted September 3, 2012 If you have used SOLPROF and then EXPLODED the block or blocks, it is also a very good idea to then run OVERKILL which will clean out any duplicates and will optimize the remaining geometry. :wink: Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 I wish I had overkill (not in 2007) as customer's drawings with lines upon lines upon lines drive me crazy. Especially when they are used for cnc profiling....cnc does not like duplicates! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 3, 2012 Share Posted September 3, 2012 I wish I had overkill (not in 2007) as customer's drawings with lines upon lines upon lines drive me crazy. Especially when they are used for cnc profiling....cnc does not like duplicates! It is really great. Do you have selection cycling in 2007? If so, that could help you also to detect and delete duplicates, but not nearly as easily as OVERKILL. Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 Yes, if by selection cycling you mean shift and spacebar to cycle through the selec.....hang on, of coursed that's what you mean! ;-) It is a help but difficult when the original drawing wasn't drawing in autocad and what was once a polyline gets blown into hundreds of tiny lines. Grrrr! Fuzz distance is a nother one that makes things a whole lot easier for me too. Not sure how long that has been about Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 3, 2012 Share Posted September 3, 2012 I shouldn't think that it would matter that it was from another program. I could be wrong about that. The image shows what I mean by selection cycling. Having started a command, then selected at an ambiguous point, because there are 4 polylines on top of one another, you are presented with a dropdown selection box. You can turn it on and off by clicking on the circled icon, or CTRL+W. The blue highlighted one is the one that the software has guessed you mean to select, and if it is correct, just hit enter. If it is wrong then you need to select the correct one from the list before hitting enter. Right click on the status bar icon to change the settings of the tool. Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 3, 2012 Share Posted September 3, 2012 I don't get the drop down box (maybe added after 2007) or the different colours but I can use shift and spacbar to highlift duplicate geometry. Somethimes when I get a file that was originally created in solidworks the exported as a dxf this can happen. Not saying it should but it's something that is done at the customer's end. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 3, 2012 Share Posted September 3, 2012 Yeah, too bad, probably added later, but just in case, look at this, never say never. Quote Link to comment Share on other sites More sharing options...
