Zauyamakanda Posted September 4, 2012 Share Posted September 4, 2012 I am using AutoCad 2007. However, I do not know how to make a road cross section using xyz data. Quote Link to comment Share on other sites More sharing options...
Zauyamakanda Posted September 4, 2012 Author Share Posted September 4, 2012 How can I quickly plot and calculate the volume of a stock-pile using AutoCad 2007? Please assist me. Thanks in advance for your help. Quote Link to comment Share on other sites More sharing options...
Zauyamakanda Posted September 4, 2012 Author Share Posted September 4, 2012 Is it possible to generate contours in AutoCad 2007? If yes, how can I generate contours given levels of a road? Please help me. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 4, 2012 Share Posted September 4, 2012 Please create new posts in the appropriate forum instead of added to unrelated threads. I have moved combined your posts into one thread. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 4, 2012 Share Posted September 4, 2012 Using vanilla AutoCAD 2007, you will either need some add-ons (like Carlson or Dotsoft Mapworks) -or- you'll have to do the calcs manually and make use of AutoCAD for the drafting portion. Quote Link to comment Share on other sites More sharing options...
Organic Posted September 5, 2012 Share Posted September 5, 2012 I am using AutoCad 2007. However, I do not know how to make a road cross section using xyz data. You can't do it easily. You will have to draw the cross sections manually. You may be able to use a lisp program if the data is in the correct format. How can I quickly plot and calculate the volume of a stock-pile using AutoCad 2007? Please assist me. Thanks in advance for your help. You can't. Is it possible to generate contours in AutoCad 2007? If yes, how can I generate contours given levels of a road? Please help me. Thanks in advance. No, it is not possible. AutoCad Civil 3D (or a similar civil program) is what you need to be able to complete tasks such as those you describe above. Quote Link to comment Share on other sites More sharing options...
luxz Posted September 5, 2012 Share Posted September 5, 2012 (edited) For contour, this maybe will help...http://www.sitetopo.com/ and try for cross-section. Edited September 6, 2012 by Tiger removed one link Quote Link to comment Share on other sites More sharing options...
